Jump to content
M1XIN # of flashes map?
  • Please log in to reply
5 replies to this topic
#1 IVB
IVB
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3613 posts
  • Experience:guru
  • Software:CQC
  • Hardware:Elk M1
  • Tech:Z-Wave
  • Audio:Nuvo
  • CCTV:ip
Posted 28 May 2018 - 07:24 PM
Debugging a problem with 2 of my M1XINs after a recent power surge. Can't find a map/legend of what the # of flashes on the LED means. Assuming I don't find it the second I press "post new topic", can you help a guy out :-)
#2 wuench
wuench
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1654 posts
  • Experience:guru
  • Software:Harmony, Open Source Automation
  • Hardware:Elk M1, ISY-99
  • Tech:INSTEON, Z-Wave
  • Audio:Sonos
  • Video:Custom
  • CCTV:ip
  • Phone:OBi100/110
Posted 29 May 2018 - 08:06 AM
The number  of  flashes per second are the number  of home automation accessories you still have left to buy before  achieving HA nirvana.     :)
#3 42etus
42etus
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 243 posts
  • Experience:average
  • Tech:INSTEON, 1-Wire
  • CCTV:ip
  • Phone:POTS
Posted 29 May 2018 - 03:55 PM
Found this on the Elk site:
For the M1XIN "LED Blink" pattern
   1=OK
   2=No Comm
   3=Not Enrolled
   4=Invalid Address
   5=OK To Enroll
   6=Address In Use
#4 IVB
IVB
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3613 posts
  • Experience:guru
  • Software:CQC
  • Hardware:Elk M1
  • Tech:Z-Wave
  • Audio:Nuvo
  • CCTV:ip
Posted 29 May 2018 - 03:56 PM
Thanks! I couldn't find it.
I'm battling a "3" (not enrolled), but the darn thing won't enroll. I just switched from an M1DHBR to M1DBH, checking my terminations again now in case that's it. Darn frustrating...
#5 TurboSam
TurboSam
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 244 posts
  • Software:CQC
  • Hardware:Elk M1
  • Tech:X10-RF, UPB
  • Audio:Sonos
  • CCTV:ip
Posted 30 May 2018 - 10:31 AM
IVB, I suspect you have done this, but if not:  make sure you first disconnect the power from the XIN and enroll everything without it.  Then hook up power and try to re-enroll.
#6 IVB
IVB
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3613 posts
  • Experience:guru
  • Software:CQC
  • Hardware:Elk M1
  • Tech:Z-Wave
  • Audio:Nuvo
  • CCTV:ip
Posted 30 May 2018 - 10:40 AM
Thanks. I finally got this portion working. Turns out one of my keypads is always being seen as terminating the bus even though there's no terminating jumper. It wasn't the M1XIN, it just happened to sit after it on the M1DBH. Anything I added after that was wonky.
I ended up adding each device one at a time, moving that keypad down with each addition.
Yeah that took 12+ manhours to figure out. I kept recrimping wires, tried everything...
