hgupta1 said:Since output 1-3 are on the M1G board, would the 8 relays on the M1OVR board be Output 4 to 11"
mikefamig said:The address of the OVR will determine the number of it's output ports as RAL said but I wouldn't use address 2. If you expect that you may ever want to add wireless sensors then you should not use address 2 or even 3. The first wireless adapter must be at address 2 and any additional wireless adapters must follow it in address 3, 4, 5 etc. I would put the OVR and other wired adapters starting at a higher address like 12 or even higher leaving room for wireless add-ons later.
Mike.
RAL said:It's ok to use address 2 for the OVR. Each type of device has its own address range, and the addresses don't conflict with each other across types.
Keypads are type 1, zone input expanders are type 2, output expanders are type 3. So if you choose to add a wireless adapter at a later time, no problem assigning it address 2, even if you have an output expander that also is assigned address 2.
Work2Play said:Off the top of my head, there was one "gotcha" so you're not completely off, mikefamig. Maybe it was that the 2 Way Wireless had to be the first one of that type, or something along those lines...
I'll also add that an M1RB can be added to the M1's onboard voltage-only outputs even without the M1RB if you just need 8 more or so relays... for anyone else reading along.
