Jump to content
Dolphin blue vs. white
  • Please log in to reply
5 replies to this topic
#1 rockinarmadillo
rockinarmadillo
    Dedicated Cocooner
  • -=Gold Supporter=-
  • 199 posts
  • Experience:novice
Posted 01 July 2018 - 07:41 PM
Looking at Dolphin connectors, and it looks like the blue ones (with gel) are slightly cheaper than the white ones (without gel).   The gel gives some extra protection against corrosion, so is there any reason I should not use blue ones for everything?
#2 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3415 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 02 July 2018 - 07:05 AM
I can't imagine any reason not to. I used all Elk-9022 gel filled connectors in my system.
Mike.
#3 42etus
42etus
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 235 posts
  • Experience:average
  • Hardware:Elk M1, ISY-99
  • Tech:INSTEON, 1-Wire
  • CCTV:ip
  • Phone:POTS
Posted 02 July 2018 - 11:20 PM
I also used the Elk gel filled connectors. Four years in and zero issues.
Go for the gel filled.
#4 rockinarmadillo
rockinarmadillo
    Dedicated Cocooner
  • 199 posts
  • Experience:novice
Posted 06 July 2018 - 08:56 PM
Thanks!   I will go with the gel filled.
#5 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3415 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 07 July 2018 - 10:25 AM
You should know that those connectors are not meant to be crimped completely flat. They have little teeth on the inside that you don't want to crush. The correct crimping tool jaws do not close all of the way as to not crush the connector.  I also highly recommend stripping the wires even though the manufacturer says that it is not necessary.
GMP makes a professional tool that can usually be found on Ebay for an affordable price if you wait and watch.
Mike.
Edited by mikefamig, 07 July 2018 - 10:34 AM.
#6 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3415 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 07 July 2018 - 10:27 AM
I just learned that GMP has been acquired by Klein Tool
https://www.kleintoo...co-trevose-penn
