Jump to content
Fiber vs Copper for databus?
  • Please log in to reply
11 replies to this topic
#1 sbwright
sbwright
    Cocooner
  • Registered
  • PipPip
  • 77 posts
  • Software:HomeSeer
  • Tech:Z-Wave
Posted 03 July 2018 - 02:52 PM
We've finished building a new home and are getting ready to relocate our ELK security panel to the house from a detached garage. There is currently a sub panel installed in the detached garage with all the pertinent equipment and it will remain. We are pulling fiber between the 2 buildings as all our utilities/communications cables enter via the detached garage. There will be spares available.
Question is has anyone here used fiber in place of copper for the ELK batabus?
Brian
#2 Work2Play
Work2Play
    Cocoonut
  • -=Gold Supporter=-
  • 4927 posts
  • Experience:guru
  • Software:Elve
  • Hardware:Elk M1, RUC-01
  • Tech:X10-RF, UPB, RadioRA2
  • Audio:AirPlay
  • Video:XBMC
  • CCTV:ip, dvr
  • Phone:3CX, Asterisk, FreePBX, Grandstream, Ooma
Posted 04 July 2018 - 07:10 AM
It's been a couple years since I've heard much on this, but what I remember was that a few people had attempted to extend the databus in various ways (including fiber), but to date, none of these methods have been successful per Elk's own Spanky - their very knowledgeable tech who used to frequent these forums.
Here's an old thread I remember about it - Spanky does indicate that they're evaluating fiber options, and that was 9 years ago - so maybe they did eventually figure something out?   http://cocoontech.co...s-485-data-bus/
#3 Work2Play
Work2Play
    Cocoonut
  • 4927 posts
  • Experience:guru
  • Software:Elve
  • Audio:AirPlay
  • Video:XBMC
  • CCTV:ip, dvr
Posted 04 July 2018 - 09:08 AM
Reading through Spanky's comments, it almost looks like this would work - but testing it is beyond my capabilities right now (I don't even have an M1 right now - need to order it!).
https://www.serialco...neral_info.aspx
#4 LarrylLix
LarrylLix
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1117 posts
  • Experience:guru
  • Hardware:ISY-99
  • Tech:INSTEON, 1-Wire
  • Video:XBMC
  • CCTV:ip
  • Phone:Ooma
Posted 04 July 2018 - 06:07 PM
I have a pair of Black Box Media converters to sell you if you are interested. Never installed 100MBit. Can't remember the fibre type or spec but commercial quality units. I will never use them.
If you are interested send me a PM and I can dig them out and get specs etc..
#5 pete_c
    Cocoonut
  • 8998 posts
  • Experience:average
  • Audio:Russound
  • Video:MythTV
  • CCTV:analog, ip, dvr
Posted 05 July 2018 - 11:04 AM
In the early days of networking (1990's) used black box solutions for logistics in automotive assembly plants (printers) and airline freight warehouses extending this or that with copper.
Using fiber will work now a days just fine.
#6 Work2Play
Work2Play
    Cocoonut
  • 4927 posts
  • Experience:guru
  • Software:Elve
  • Audio:AirPlay
  • Video:XBMC
  • CCTV:ip, dvr
Posted 06 July 2018 - 12:32 AM
LarryLix - thx for the offer; there's likely others around who'd have more use (awesome way to connect outbuildings!).  I know I actually have a pair around here as well, and my switches are all fiber capable.
Ironically, this house I just bought was actually prewired with Fiber that wasn't terminated.  I may actually terminate and use it just to keep the Cat5 free.  Just a couple runs like to the office, entertainment center, and I'm not sure of the 3rd run yet...
#7 rockinarmadillo
rockinarmadillo
    Dedicated Cocooner
  • 199 posts
  • Experience:novice
Posted 06 July 2018 - 09:02 PM
I have been working the same issue for the Leviton/HAI databus.   I plan to buy a couple of those RS485 media converters and try it.   Should have an answer in a few weeks.
I have already spent dozens of hours and over $1000 on lightning damage repair.      I have lightning arrestors on both ends of my data bus, but I am not comfortable that they will protect me because the earth ground is too far away from my automation boxes.   Hoping that going to fiber will work.
#8 sbwright
sbwright
    Cocooner
  • Registered
  • PipPip
  • 77 posts
  • Software:HomeSeer
  • Tech:Z-Wave
Posted 17 July 2018 - 11:55 AM
Thanks Work2Play for the links to the old threads and hardware. Once the cable is pulled in I'll order the boxes and begin testing. Will feedback results here.
#9 sbwright
sbwright
    Cocooner
  • Registered
  • PipPip
  • 77 posts
  • Software:HomeSeer
  • Tech:Z-Wave
Posted 17 July 2018 - 11:57 AM
Good luck rock, looking forward to hearing your results.
#10 Work2Play
Work2Play
    Cocoonut
  • 4927 posts
  • Experience:guru
  • Software:Elve
  • Audio:AirPlay
  • Video:XBMC
  • CCTV:ip, dvr
Posted 18 July 2018 - 01:25 AM
Looking forward to seeing your results!  Wish I could help.
#11 rockinarmadillo
rockinarmadillo
    Dedicated Cocooner
  • 199 posts
  • Experience:novice
Posted 21 July 2018 - 03:08 PM
Success!   It was very close to plug and play.
I used a pre-terminated multi mode fiber from the house to the garage (pulled thru conduit about 300 ft)
I bought a SER-FIBER-MM modem for both ends.
I used the power supply on the Omni pro II alarm panel to power the modem at both ends.   The fiber modem comes with a 12v power supply that I did not use.   If you use that one, be sure to tie the panel ground to the negative on the power supply.   They need to have a common reference voltage.
It did not work at first, but then I reversed the two fibers and it started working immediately.   I never seem to get the fiber polarity right the first time.
Tie the panel data bus A to the modem T+/D+  and the panel data bus B to the modem T-/D-
I will monitor to assure that the connection is reliable, but it looks rock solid at this point.
#12 Work2Play
Work2Play
    Cocoonut
  • 4927 posts
  • Experience:guru
  • Software:Elve
  • Audio:AirPlay
  • Video:XBMC
  • CCTV:ip, dvr
Posted 21 July 2018 - 11:19 PM
Awesome!!  I wonder if someone can try the same with the Elk?
