I have an old Foxconn D525 mini ITX motherboard with all aluminum SMD electrolyic caps.
Had an issue with the motherboard and it not running for more than 3-4 minutes.
Looking at the board noticed one of the SMD Aluminum electrolytic caps was bulging. First time I have seen this on an aluminum cap.
Size: 7mm X 8mm
471uF 6.3VDC
Purchased a bulk pack of SMD Aluminum caps but they are too small for me to install. I have no work space on the motherboard.
Size: 6.3mm X 7.7mm
470uF 6.3VDC
Decided to utilize a rubycon MFG electrolytic capacitor. It looks like a regular style small electrolytic capactor.
Size: 8mm X 11.5mm
470uF 6.3VDC
Will this work?
Size: 7mm X 8mm
471uF 6.3VDC
Size: 6.3mm X 7.7mm
470uF 6.3VDC
Size: 8mm X 11.5mm
470uF 6.3VDC
Will this work?
