Jump to content
M1XEP HELP
  • Please log in to reply
4 replies to this topic
#1 little66085
little66085
    Cocooner
  • Registered
  • PipPip
  • 28 posts
Posted 12 September 2018 - 03:27 PM
Hi all,
Suddenly, my M1XEP became invisible.  RP cannot locate it.  I have rebooted the internet and re-powered the M1XEP but no luck.  Any ideas?  Thanks in advance for your help!
#2 RAL
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1925 posts
  • Experience:average
  • Hardware:Elk M1
  • Tech:X10-PLC
  • Phone:POTS
Posted 12 September 2018 - 04:35 PM
When you say RP can't find it, do you mean when you do a Find from the M1XEP Setup screen?  If so, that doesn't sound good.
I would check that the XEP is getting 12V from it's power source.   If that's ok, next check/swap the ethernet cable going to the XEP.
Log in to your router and look at its list of connected devices to see if the XEP's MAC address is showing up.
There are also some troubleshooting steps you can follow at the end of the XEP manual.
If none of that works, I'd say your XEP is probably dead.
#3 little66085
little66085
    Cocooner
  • Registered
  • PipPip
  • 28 posts
Posted 12 September 2018 - 05:04 PM
Well, you confirmed my suspensions.  My router does not show it as a connected device, I have 12+v power and swapping the cat6 is not helping.  I do have an orange light on the XEP and cannot remember if it was always that color.
#4 treo650
treo650
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 192 posts
Posted 12 September 2018 - 05:32 PM
I've had this happen before. Run a search on these forums how to jumper your m1xep into dhcp mode. After a power outage for some reason the unit gets itself into a static or non dhcp mode where the network does not pick up an ip address
#5 RAL
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1925 posts
  • Hardware:Elk M1
  • Tech:X10-PLC
  • Phone:POTS
Posted 12 September 2018 - 05:44 PM
That's worth a try, but usually the Find command will find an XEP no matter which mode it is in, even if it hasn't been assigned an IP address.
