Jump to content
Sensor on a chain link fence gate
  • Please log in to reply
11 replies to this topic
#1 Smcross03
Smcross03
    Cocooner
  • Registered
  • PipPip
  • 42 posts
Posted 02 April 2019 - 05:24 PM
Has anyone ever installed a sensor on a chain link fence gate to know if it is open or not? If so, how did you do it? I have an elk with the Honeywell wireless receiver so a wireless solution would be ideal, but Im open to suggestions! Thank you
#2 TrojanHorse
TrojanHorse
    Cocooner
  • Registered
  • PipPip
  • 72 posts
  • Experience:novice
  • Hardware:Elk M1, ISY-99
  • Tech:INSTEON
  • Audio:Custom
  • CCTV:ip
Posted 02 April 2019 - 06:21 PM
What type of gate? Sliding, swinging, dual swinging that meets in the middle? I’m about to install a Seco-Larm SM-226RQ on my sliding driveway gates. They have wood that I’ll attach to but you could make it work with metal. I will hardwire mind to the Elk. Sent from my iPhone using Tapatalk
#3 Smcross03
Smcross03
    Cocooner
  • Registered
  • PipPip
  • 42 posts
Posted 02 April 2019 - 06:38 PM
It is a gate for a chain link fence so I have two metal poles to mount to. No flat surfaces at all.
#4 lanbrown
lanbrown
    Cocooner
  • Registered
  • PipPip
  • 59 posts
  • Software:Indigo
  • Hardware:CaddX
  • Tech:Z-Wave
Posted 02 April 2019 - 06:47 PM
Couldn't you just put a sensor on the inside part where it the gate would swing away from it?  With it being a chain linked fence, it is not like you could use it for when someone opened the gate without you knowing since it would all be exposed anyway.  So it would just be a simple contact sensor.  Alternatively, you could also place it on the latch portion since you would need to raise the latch to open the gate.
#5 Smcross03
Smcross03
    Cocooner
  • Registered
  • PipPip
  • 42 posts
Posted 02 April 2019 - 06:55 PM
IanBrown,
Yeah that is what I was thinking, but I wasnt sure if there were some specific sensors for my application. All the outdoor rated sensors Ive seen are square in shape and I wasnt sure how that would look on a round pole. I probably wouldnt even be doing this but we have a new puppy and, twice now, the gate has been left open and she went out on an adventure. We cant see this particular gate so it would be nice to know if it is open before she goes out. Thank you for the suggestions!
#6 TrojanHorse
TrojanHorse
    Cocooner
  • Registered
  • PipPip
  • 72 posts
  • Experience:novice
  • Tech:INSTEON
  • Audio:Custom
  • CCTV:ip
Posted 02 April 2019 - 07:16 PM
What outdoor sensors were you looking at? Curious as I’m not sure how mine will hold up outdoors over time... I think you could drill a couple holes in the posts to mount a sensor. Or even zip ties if you can’t see it and it’s not for security per se and you’re not concerned about tampering. Edit: or pipe clamps / hose clamps instead of zip ties. Nearly as quick and better. You said you can’t see it so I’m assuming aesthetics isn’t a big issue. Sent from my iPhone using Tapatalk
Edited by TrojanHorse, 02 April 2019 - 07:27 PM.
#7 Smcross03
Smcross03
    Cocooner
  • Registered
  • PipPip
  • 42 posts
Posted 02 April 2019 - 07:42 PM
The Honeywell 5816OD is what I was looking at.
#8 TrojanHorse
TrojanHorse
    Cocooner
  • Registered
  • PipPip
  • 72 posts
  • Experience:novice
  • Tech:INSTEON
  • Audio:Custom
  • CCTV:ip
Posted 02 April 2019 - 07:52 PM
That looks good. Looks like you could play around with it. It has an option to connect an additional contact so you could try some cheaper smaller sensors connected to it and conceal the larger sensor somewhere else. How big is the gap between posts that you’re trying to monitor? Edit: I assume you’re comfortable that would be within RF range? Sent from my iPhone using Tapatalk
Edited by TrojanHorse, 02 April 2019 - 07:55 PM.
#9 Smcross03
Smcross03
    Cocooner
  • Registered
  • PipPip
  • 42 posts
Posted 02 April 2019 - 08:05 PM
I think I will give the 5816OD a try. After looking at the install manual it has provisions for zip ties which I think would be preferable in my situation. The distance would definitely be within range. Its probably less than 30 feet as the crow flies from the wireless module.
Thanks for all the input!
#10 RAL
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1968 posts
  • Experience:average
  • Hardware:Elk M1
  • Tech:X10-PLC
  • Phone:POTS
Posted 02 April 2019 - 08:27 PM
You could use a garage door magnetic contact.  They are designed for a larger gap than many others, and many are weatherproof.
Here's one example.
https://www.amazon.c...s/dp/B0006M1I1W
#11 TrojanHorse
TrojanHorse
    Cocooner
  • Registered
  • PipPip
  • 72 posts
  • Experience:novice
  • Tech:INSTEON
  • Audio:Custom
  • CCTV:ip
Glad to help. Let us know how it turns out! I could be interested in using that same sensor at some point but would need to add the Honeywell RF module first. I don’t think Elk makes an outdoor sensor like that for their RF module. Sent from my iPhone using Tapatalk
#12 batwater
batwater
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 273 posts
  • Experience:guru
  • Software:CQC, EventGhost, Harmony, Custom
  • Hardware:DSC, Custom
  • Tech:X10-RF, UPB, Z-Wave, ZigBee
  • Audio:Sonos
  • Video:Custom
  • CCTV:analog, ip, dvr
  • Phone:Asterisk, OBi100/110
Posted 13 April 2019 - 08:19 PM
Not quite what you are looking for but I used a Zwave door module sealed in a PVC pipe with a heavy duty door magnet. Been working flawlessly for 2+ years.  Did have to put in 2 zwave repeaters in the house closest to the fence gates, I have 3 gates, all are monitored.
