Jump to content
Outdoor Wireless Access Point Recommendations
  • Please log in to reply
16 replies to this topic
#1 BraveSirRobbin
BraveSirRobbin
    Cocoonut
  • Moderators
  • PipPipPipPip
  • 7471 posts
Posted 22 April 2019 - 07:21 AM
My friend has a fairly large property (200' x 200') with multiple houses, sheds, garages, etc... where WiFi is needed (from one access point coming from the house.  The house isn't centered in the property.  She does have a pole a bit outside the house where she has power available.   I was thinking of using something like THIS to place on that pole for overall coverage (not to expensive and should do the trick) but many members here have a lot of experience dealing with problems like this.
https://www.amazon.c...2b-df456cd2a423
IN case link is incorrect; EnGenius 802.11ac Wave 2 2x2 Dual Band, high-powered, Outdoor wireless AP with external detachable antenna, 27dBm, 24V PoE, quad-core CPU, MU-MIMO, Beamforming, IP55 (ENS620EXT)     Am I going in the correct direction?  Can you recommend another method?
Edited by BraveSirRobbin, 22 April 2019 - 07:24 AM.
#2 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3545 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 22 April 2019 - 08:28 AM
You can also go with an outdoor antenna
https://www.amazon.c...tronics&sr=1-10
but it would require pulling a cable so your access point is easier being that it uses the existing AC power on the pole.
#3 mdesmarais
mdesmarais
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 420 posts
  • Experience:average
  • Software:HouseBot
  • Hardware:Custom
  • Tech:X10-PLC, X10-RF, INSTEON, Custom
  • Audio:Custom
Posted 22 April 2019 - 10:48 AM
I've been using Ubiquity for a long time... I put a outdoor access point up on the second floor (indoors actually) and it covers pretty much my whole property (1 acre). One other access point in the basement as it got a little low down there. Pro level management SW.
#4 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3545 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 22 April 2019 - 11:52 AM
I have internet cabled to my detached garage through a buried conduit so I was able to put a wireless access point router indoors there.
Mike.
#5 BraveSirRobbin
BraveSirRobbin
    Cocoonut
  • Moderators
  • PipPipPipPip
  • 7471 posts
Posted 23 April 2019 - 06:48 AM
She wanted both 2.4 and 5 GHz so that antenna wouldn't work.
For Ubiquiti, which would you recommend?
https://www.amazon.c...B5YH8N1MS84K24T
or
https://www.amazon.c...7JMMF5C6N0CJ77B
#6 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3545 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 23 April 2019 - 07:42 AM
or
I don't know a whole lot about networking, just what I've taught myself. The Ubiquiti UAP-AC-M-PRO-US Unifi Access Point claims a faster speed and has more positive reviews so I like that but it costs more. I suppose I go i'd th that one. These devices are pretty common and i'd bet that they would both do the job in a small yard. I'd be mostly concerned about the device's ability to withstand the weather. That's why I put mine inside. Look for an IP65 or IP67 rating for weatherproofing.
http://www.dsmt.com/...p-rating-chart/
Mike.
#7 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3545 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 23 April 2019 - 08:00 AM
https://www.bestrevi...range-extenders
#8 LarrylLix
LarrylLix
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1375 posts
  • Experience:guru
  • Software:Custom
  • Hardware:ISY-99, Custom
  • Tech:INSTEON, 1-Wire, Custom
  • Audio:Custom
  • CCTV:ip
  • Phone:Ooma
Posted 23 April 2019 - 08:19 AM
I have a 200 x 200' property and I use a single Asus AC1900 router. My SSID can be picked up many lots down the street. I turned my 2.4 and 5GHz down to 15-25% power and things  have worked much better.
I believe those little antennae cannot handle the power from two frequencies simultaneously without distorting the signals. My wife's iPad could not receive the 5GHz from 15' across the room, until I lowered the output power. But then that is an Apple product so who knows?
I keep my router on top of a cabinet near the ceiling, on the main floor of my bungalow inside a brick home. There are some weak spots under the staircase at the far end of the home, but I suspect the Venstar stat there is a known bad WiFi unit, as both of the Venstar units I have, refuse to heal with this router anyway.
With larger properties and lots of distance between neighbours, there shouldn't be much rf noise or competing WiFi. Do not choose Channel 1 or 6, or automatic selection (default)  on 2.4 Ghz,  and keep the 5Ghz to channels that are not on the Radar disconnect list if anywhere near any aircraft flight paths or aeroports. 5Ghz has it in the spec to immediately shut down and change channels due to radar sharing the frequencies. Avoid those channels
#9 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3545 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 23 April 2019 - 08:48 AM
I have an Arris NVG448BQ router installed by Frontier cable and it doesn't reach my back yard about 200' from the router. It is located near the ceiling of the ground floor near the rear of the house.
I have a wifi scanning software and have set the router to a channel that is different than any in the area. It sounds like that Asus Tx is doing a great job for you.
Mike.
#10 pete_c
    Cocoonut
  • -=Gold Supporter=-
  • 9681 posts
  • Audio:Russound
  • Video:MythTV
  • CCTV:analog, ip, dvr
Posted 23 April 2019 - 08:51 AM
Helped a friend with his farm and multiple homes / barns and outbuildings and just ran cable underground to another home ~ 300 feet away and installed another AP there.
Wired 2nd home is on top of a hill and highest point on his property.
Attached File  farm.jpg   39.87K   3 downloads
BTW not sure of the footprint you will get with 5Ghz or even the need for it outdoors.  (200 feet isn't really a huge distance anyhow).
#11 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3545 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 23 April 2019 - 08:58 AM
I have the free version of Acrylic wifi scanning software and it's a very handy tool
https://www.acrylicw...ylic-wifi-free/
#12 mdesmarais
mdesmarais
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 420 posts
  • Software:HouseBot
  • Hardware:Custom
  • Audio:Custom
Posted 23 April 2019 - 01:40 PM
or
I'm no expert either... but my understanding is that the bigger unit would be better for multiple high speed users. I would guess that a small number of users would probably not see much difference between these two units, unless one was a streaming gamer. ;-)
#13 LarrylLix
LarrylLix
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1375 posts
  • Experience:guru
  • Software:Custom
  • Audio:Custom
  • CCTV:ip
  • Phone:Ooma
Posted 23 April 2019 - 09:37 PM
Mike.
Things were not so good originally. I kept increasing the RF output levels and it got worse. Then I tried very low RF output levels and the distance for both frequencies increased greatly. Also, then  my router stopped overheating and became much more reliable. People over 5-600 feet away can still see my SSID beacons quite well.
#14 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3545 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 24 April 2019 - 06:38 AM
How do you explain that? I would think that decreasing the power would decrease the range. My router shows 100% output but I don't think that it can be adjusted. I'll have to have another look.
Mike.
EDIT - I looked again and found that I can adjust the RF power as low as 50%. I'll try lowering it and see what happens.
Edited by mikefamig, 24 April 2019 - 06:43 AM.
#15 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3545 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 24 April 2019 - 06:56 AM
Good info on wifi RF here
https://metis.fi/en/2017/10/txpower/
Edited by mikefamig, 24 April 2019 - 10:18 AM.
