TristateUser
Hi,
I have been observing that the clock on my Omni LT was drifting a few seconds every day and as a result I have to re-synch clock every week using PC Access Dealer (via Communications -> Set Controller Time).
I noticed that there is a field called "Clock Adjust" under Miscellaneous Settings in PCA which is currently set to 43 by the previous owner of the house. Is tinkering with "Clock Adjust" value the correct way to fix this issue? (I didn't try to change "Clock Adjust" value because I was not sure what it is really meant for). Please help. Thank you
