Jump to content
MQTT Home Assistant GDO request for help
  • Please log in to reply
3 replies to this topic
#1 pete_c
    Cocoonut
  • -=Gold Supporter=-
  • 9990 posts
  • Experience:average
  • Audio:Russound
  • Video:MythTV
  • CCTV:analog, ip, dvr
Posted 10 August 2019 - 04:04 PM
Modified a Sonoff basic here for a GDO button, closed door, open door, intermediate door and temperature sensor.
Using HA what is the best way to configure this device in configuration.yaml or a script?
GDO1
Noticed that there is a HA MQTT function called cover which can be used for a garage door.
#2 vc1234
vc1234
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 330 posts
Posted 11 August 2019 - 11:36 AM
Probably, the simplest way would be to use an MQTT switch:
https://www.home-ass...ts/switch.mqtt/
That's what's been working for me with another opener, not sure about the Sonoff. I was not even aware that the MQTT cover existed.
In any case, I'd use mosquitto_sub to see what messages flow between HA and the Sonoff.
#3 pete_c
    Cocoonut
  • 9990 posts
  • Audio:Russound
  • Video:MythTV
Posted 11 August 2019 - 06:52 PM
Thank you vc1234
Yes this is a custom SonOff firmware with hard wired reed switches / sensors on the top and bottom of the garage door plus using button for opening and closing door plus a DS18B20 1-wire temperature sensor.
I have it working right now using mcsMQTT in Homeseer.  Trying to replicate same in HA.
This is a testing project as the GDO / Garage doors sensors are also wired to the alarm panel.
sonoff
#4 Linwood
Linwood
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 433 posts
Posted 28 August 2019 - 06:33 PM
I've just been experimenting with MQTT with EXPHOME stuff.
Separately I have my doors in HA as covers (via MyQ).
If you can get an open/closed (or similar) status, I would set it up as covers, then the icons and indicators will be more natural.  I'm running Mosquitto on the HA instance.
