Jump to content
Omnipro II contact ID reporting via Inner range t4000
  • Please log in to reply
1 reply to this topic
#1 Huish
Huish
    Newbie
  • New Member
  • Pip
  • 1 posts
Posted 28 August 2019 - 10:58 PM
Hi all,
As the title says, I'm trying to get my omnipro II reporting to a monitoring centre via an Inner range t4000. No matter what I do I cannot get it reliably reporting. I've definitely got the programming side ok, as I have had it report a few alarms, but more often than not the monitoring centre receives nothing at all. Now I have tried various cables, I have replaced the omnipro panel itself, and still can't get it to work. Has anyone else successfully used a t4000 with a leviton panel?
#2 ano
ano
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3534 posts
  • Experience:guru
  • Hardware:HAI OmniPro II
  • Tech:UPB, ZigBee
  • Audio:HAI
  • Phone:Ooma
Posted 29 August 2019 - 01:22 PM
Hello and welcome.
I can't answer your question on the t4000, but is this the device your monitoring company suggested for your panel?  Most monitoring companies have a list of one or two devices which they support, they mail them to you, you connect them, and everything is set. Then its up to the monitoring company to get it to work, and no doubt, they have more experience with it than you do.
There are two protocol connections in play here. The alarm panel to the device, and the device to the monitoring company. The alarm panel to the device usually uses contact ID protocol which just takes two wires and is hard to screw-up. Between the device and alarm company may be standardized or maybe not. The monitoring company should be in control of this.
When I signed up with AlarmRelay, they sent me a communicator which they told me in advance only had a 50-50 chance of working with the OmniPro II but it was the cheaper option. It ended up not working, so they sent me a different model that works great, but costs $2 more a month to monitor. They had lots of experience with OmniPro II's and knew what worked and what might work.
Long-story-short, the monitoring company should be in charge of getting this working. If the first one doesn't, they will likely know another one to try.
