Jump to content
direct burial network cable - should I get gel filled?
  • Please log in to reply
17 replies to this topic
#1 JimS
JimS
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 645 posts
  • Experience:average
  • Software:Mister House
  • Hardware:Custom
  • Audio:Custom
  • Video:MythTV
Posted 18 January 2020 - 10:43 AM
Need to run about 270 ft to another building and putting in conduit.  But buried conduit gets moisture and is considered wet.  Don't need 1000 feet so was looking at 500 ft spools - enough for the foreseeable future and then some although I could go for 1000 if that's what's needed to get good cable.  Lots of choices and most have waterproof tape rather than gel which seems not as good.
I know to avoid CCA (copper coated aluminum) but otherwise what other things should I be looking for?  Planned to buy Cat6.
Looking at wireandcablemyway.com, monoprice, and amazon although I just found this on ebay:
https://www.ebay.com...5.c100005.m1851
#2 RAL
    Cocoonut
  • Registered
  • PipPipPipPip
  • 2112 posts
  • Hardware:Elk M1
  • Tech:X10-PLC
  • Phone:POTS
Posted 18 January 2020 - 08:38 PM
I try and stay away from Logico brand cable as I don't consider them a reputable, name brand like Paige, Coleman or General Cable.  Some of the Logico cable is CCA, some is solid copper.  All made in China.  They don't always specify what it is on the packaging, which leaves me suspicious.  One box of cable I bought turned out to be CCA, but was not labeled as such.
If you go to their web site, they claim to be a "100% owned and operated brand," whatever that means. They show a picture of a cable factory, leading you to think they own it. Yet, their corporate headquarters is a store front in a business strip mall, without even the company name on the door.
#3 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3571 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 20 January 2020 - 01:00 AM
Are you familiar with Primus cable? I used their gel filled cat6a cable here and it's been buried in a conduit for some years now and working well. Based on my experience i would use it again.
https://www.primusca...l-filled-23-awg
Mike.
#4 JimS
JimS
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 645 posts
  • Hardware:Custom
  • Audio:Custom
  • Video:MythTV
Posted 20 January 2020 - 12:59 PM
Mike.
Looks good but also pricey...
#5 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3571 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 20 January 2020 - 01:18 PM
It's too much work to replace for me to worry over a couple of bucks. I'll spend a little more to not have to look back.
If I change an external fan belt on my car I'll go for a bargain becasue it is easy enough to replace but when I change the timing belt I'll buy the best.
Mike.
#6 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3571 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 20 January 2020 - 03:24 PM
Keep in mind that if the cable fails you will lose all data to the building and it can take some time and money to pull it out and replace it. That cable that I linked to is also cat6a which I figure will be sufficient for years to come (I hope).
Mike.
Edited by mikefamig, 20 January 2020 - 03:34 PM.
#7 JimS
JimS
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 645 posts
  • Hardware:Custom
  • Audio:Custom
  • Video:MythTV
Posted 20 January 2020 - 10:09 PM
Yes, I agree it is worth more to not have to replace it later.  And I found it wasn't as much more as similar products as I initially thought...
#8 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3571 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 21 January 2020 - 09:13 AM
I tried to add a cable to my 200' long buried conduit using a rope that I had left in there just for this reason but it was impossible. I ended up needing to remove the existing cables and pull them all together again, re-splicing it all, not fun. Even now I wish I had used one or even two extra cables but I didn't because of the cost.
Mike.
#9 rockinarmadillo
rockinarmadillo
    Dedicated Cocooner
  • -=Gold Supporter=-
  • 226 posts
  • Experience:novice
Posted 22 January 2020 - 10:06 AM
Consider running pre-terminated fiber.   I ran copper and then pulled it out after getting hit by lightning.  (twice)   The media converters on both ends are relatively inexpensive and plug and play.   It will cost a little more, but for my installation it was worth it.
#10 batwater
batwater
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 281 posts
  • Experience:guru
  • Software:CQC, EventGhost, Harmony, Custom
  • Hardware:DSC, Custom
  • Tech:X10-RF, UPB, Z-Wave, ZigBee
  • Audio:Sonos
  • Video:Custom
  • CCTV:analog, ip, dvr
  • Phone:Asterisk, OBi100/110
Posted 24 January 2020 - 09:33 AM
^^^This^^^!!!
Having been hit by indirect lighting twice in the last 15 years I now user fiber runs between all of my network switches and between my cable modem and my router for some level of isolation. The cable modem run uses media converters at each end, the others are run through a Ubiquiti fiber switch that is connected to the router.  You also don't necessarily need to use media converters if you use switches / router that have fiber ports such as most of the Ubiquiti EdgeSwitch / EdgeRouter lines.
We are building a new house in a few years with an out building and I will run fiber between the two structures. Will likely run a 4-8 pair cable for things other than network.
I have had outstanding luck with Fiber Store. They are extremely helpful and the prices are excellent.
#11 Work2Play
Work2Play
    Cocoonut
  • 4952 posts
  • Experience:guru
  • Software:Elve
  • Hardware:Elk M1, RUC-01
  • Tech:X10-RF, UPB, RadioRA2
  • Audio:AirPlay
  • Video:XBMC
  • CCTV:ip, dvr
  • Phone:3CX, Asterisk, FreePBX, Grandstream, Ooma
Posted 24 January 2020 - 05:28 PM
I'd 100% agree on the fiber if you're doing ethernet - plenty of switches have fiber GBICs available even.  If that's not feasible, then I'd just pick up a box of Ubiquiti ToughCable.  I've used it on plenty of tower installs, between buildings, etc.  L2 if it's truly exposed; L1 if it'll be in conduit.  As long as you terminate it properly, you should be good - the only failure I've had was from a direct lightning strike to a tower - but then again, half the tower exploded so you can't expect much from 24 gauge gable at that point.
#12 JimS
JimS
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 645 posts
  • Hardware:Custom
  • Audio:Custom
  • Video:MythTV
Posted 26 January 2020 - 09:22 AM
^^^This^^^!!!
I did a little looking at the fiber store and unless I am missing something I can do fiber cheaper than CAT6 direct burial cable.  I need 1 gigabit speed and run is 300 ft.  I didn't see anything on wet rating.  This will be in conduit so mechanically protected but wet.  dual fiber total price looks much cheaper than 1.  Not knowing quite what I am doing here are some prices on possible hardware:
35333 Media converter  $26  (two needed)
SM-LCU-LCU-DX-FS-XM-PVC  300 ft   $23.29
29848   1000BASE-SX SFP transceiver $11 (two needed)
Apparently I also need a cleaner:
39721   $57
Total is $154.29
Looks like I have a few minor things remaining like power supplies for the converters and patch cables to make a true comparison.  Am I right on the above parts?  I will contact the company to check as well.
What is the size of the end terminations?  (how big of conduit do I need?)
It looks like I could do something like this for a switch with fiber ports
https://www.amazon.c...306884547&psc=1
but what do I need for the other end?  Are the fiber terminations standard or do I need to worry about what sort of end termination?  The price looks reasonable - not that much more than a converter and switch and probably better quality than the cheap switches I am comparing to.
Edited by JimS, 26 January 2020 - 09:24 AM.
#13 rockinarmadillo
rockinarmadillo
    Dedicated Cocooner
  • 226 posts
  • Experience:novice
Posted 26 January 2020 - 02:29 PM
I used pre-terminated cable with pulling eyes.   It will cost quite a bit more that what you have quoted, but you dont have to mess with the end terminations.   Search for model 29611
I recommend LC duplex connectors on both ends.  They are widely used and compact.
Your converters need to be matched to your fiber.   I used multimode 50/125 fiber.   Seemed like a good price point that will work for short distances.   Your converters need to have a GIBC that has LC connectors.
If you use fiber converters, you dont need a fiber switch.   You will just run a cat 6 patch cable from the fiber converter to your conventional switch.   I eventually upgraded to an Ubiquiti fiber switch on both ends of the fiber.   I wanted managed switches.   The fiber converter worked just fine before the upgrade, though.
I was very careful when pulling the fiber.   I used lots of lubricant in the conduit and pulled with minimum tension.   Be careful not to kink the fiber or pull it across a sharp edge.
I am not an expert, but was able to get my system up and running with a little effort.    It has been rock solid.   No maintenance required.
#14 JimS
JimS
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 645 posts
  • Hardware:Custom
  • Audio:Custom
  • Video:MythTV
Posted 26 January 2020 - 03:32 PM
I was under the impression that what I was looking at included terminations since they were pictured and in the description.  But now I am not sure...  I was looking at 74192.
https://www.fs.com/products/74192.html
Doesn't appear to be intended for outdoor conduit locations.  Will see what they respond with - I told them my application details.
#15 rockinarmadillo
rockinarmadillo
    Dedicated Cocooner
  • 226 posts
  • Experience:novice
Posted 26 January 2020 - 03:47 PM
Yes, that is a patch cable with end terminations.
