Jump to content
Fibaro with VRCOP
  • Please log in to reply
1 reply to this topic
#1 got2weims
got2weims
    Cocooner
  • Registered
  • PipPip
  • 11 posts
Posted 26 January 2020 - 09:40 AM
I’m trying to integrate a Fibaro zwave flood sensor into my Elk M1. I have lights/receptacles all nicely controlled using  VRCOP and M1.  I have a couple new areas that I want to add flood sensors but can’t run wiring to those areas so was trying zwave sensor.  I was able to add the fibaro to my network and can read what’s coming in on the VRCOP (using putty) when it senses water, but if I try to add an automation rule using WHENEVER REC TEXT in my M1, it is not sensing the message.  Anyone have experience with this?
#2 ASIHome
ASIHome
    Dedicated Cocooner
  • Vendors
  • PipPipPip
  • 525 posts
Posted 27 January 2020 - 02:02 PM
Not something I tried on an ELK panel but when I wanted to use Z-Wave sensors on my Omni panel, I had to split the output of the VRC0P to 2 separate serial ports and set the 2nd port as a standard (PROLINK on Omni) port. There may be something similar that has to be done with the M1.
