120V Smoke Detectors + ELK
opie
I have an ELK install for a customer that had the Electrician run 120V lines for the smoke detectors and really wants to make use of this investment. He also wants them monitored by the ELK panel.
I know there are 120V models that have relays but I am curious what models others have used and pros/cons to doing it this way.
Two detectors I am looking at are the System Sensor 100 series w/ bases that contain relays, and the ESL 320A/320ACC series.
Any others I should look at?
I believe in most areas 120V smokes are required by code, so I do not really look at that as an 'investment', but more of a requirement. Depending on the device and internal vs external detector, the relay may not work during a power outage. IMHO, putting in dedicated 12V smokes and heat detectors into the panel are an 'investment' and should be used. I always leave 120V ones as they are and just add the 12V ones, sometimes right near an existing one. I believe they are higher quality detectors and they work properly in power outages.
opie
In this area, the requirement is that the smoke dectors be powered by the house's electrical system and have a battery back-up. Since the alarm panel is powered by the house's electrical system this meets requirement #1 and the alarm panel's battery back-up meets requirement #2. As I understand it, this is based on NFPA 72. Option #2 is to have 120V detectors powered directly by the mains with individual battery back-up.
See more info here.
I agree 100% that the Low Voltage line of detectors are better and have many more features. Maybe I should just push harder for the LV detectors but I also want to try to meet my client's needs.
Spanky @ Nov 13 2006 said:
Ever considered wireless smokes like the GE series. They work very good.
Sorry, I should have specified this is new construction so I have to meet the wired requirements.
The System Sensor bases I am considering have relays for Alarm and Supervision so that should cover power failure issues I think. Take a look at these bases to see if I read it right. The diagram to hook these up is below.
Seems like thses might work???
bmil
I use the ESL 350 series. 6 350's and 1 350cx wired in tandem. The 350cx has the relay and was conveniently located next to my equipment room. It is tied into an Elk M1 zone.
