An issue I have had out there for awhile and recently went back to try and resolve:
I had 4 System Sensor 2WTAB detectors installed and I added a 5th. When I added the fifth I had also added a reversing relay and a 2W-MOD2 (clean-me type signal addition to interface with the elk).
http://www.automatedoutlet.com/product.php...&cat=199&page=1
I started getting some false alarms, which I assumed was tied to the other pieces or the latest detector being added.
Some time passed and I removed the reversing relay and the 2W-MOD2 so that it is just a series of 2-wire detectors, on zone 16, with the jumper set for 2-wire smokes and the panel programmed as 10-Fire alarm, and type 6 - 2 wire smoke. When I check the status in ElkRP, the state is EOLR and the volts is 12.2.
What I was attempting to do was verify the cutoff timers worked so I could leave the detectors connected and run tests to see if a false occurred, and if so, then remove the latest detector and run it again.
I set the cutoff timers for 30 seconds and triggered the detectors using a spray tester.
The alarm sounded, but did not cut off. I went down to the keypad and tried to reset the detectors using option 2. When the alarm is sounded it would not let me hit the key to the right to 'activate' the command. When the alarm was not sounded, I could hit the option to the right and reset the alarm (I would hear a relay type reset sound at the panel and a brief message at the keypad).
The speaker connected to the panel (output 2) still makes the clicking sound that I thought might be related to the reversing relay when the alarm for the smokes is activated.
My assumptions have been dashed, and it seems I have missed something. If there are any recommendations on how to troubleshoot this or review further I would appreciate any ideas.
