24 port switch in enclosure
chaseru
I'm ready to hook up my structure wiring enclosure for my home under construction. It is a Greyfox Titan enclosure and there are about a 100 wires terminating in it, so it’s quite crowded. I would like to use the cute matching Greyfox 5 port switch or even their 8 port router but I need at least a 16 port switch, which I'll attached in the lower part of the Titan used Greyfox's third party Velcro straps.
Any suggestions for a compact switch. The best I've seen is this Linksys one:
SR2024C
BTW: this is a great site, I've found some fine info here as I've planned my home especially pushing me to purchase my ELK M1 gold.
Aquatic
You can always cascade 2, 3 or more switches rather easily. Usually either port 1 or the last port (5, 8, 16 etc depending on the size) is an auto sensing "uplink" port. Just use a short piece of wire, straight through connectors, and use the same port.
Not at all uncommon and often a stack of 5 or 8 port switches fit better in cabinents than a full 16 port version.
Good Luck!
electron
Administrator
Staff member
I believe I am using that same netgear switch in my channelvision enclosure as well (forgot the # of ports, but looks identical).
gregoryx
The Linksys switch has a fan.
Many of the Netgear switches do not. I use them for that reason: no fans.
They still expect a little airflow, I'm sure, but it hasn't proven to be a problem. I use one of their 24-port gig switches tucked up under a desk and it has not had issues.
WilliamH
We use a Linksys SRW2024 for our network at the office, its very reliable but yes it has a fan and it's a bit noisy. The fan will help keep it cool especially in an enclosure. We sold a couple to our customers and had only good feedbacks. If you dont mind the noise, I'd definetely go with the Linksys over the Netgear as far as reliability goes.
electron
Administrator
Staff member
<2cents>
I have deployed tons of NetGear equipment and have yet to see 1 device go bad.
As for the fans, I prefer them without a fan as well. A fanless device is meant to be used without a fan, a device with a fan can become troublesome when the fan fails.
</2cents>
Here's my NetGear in action:
click to enlarge
It's only a 16 port, but it gives you a good reference as to how much space a switch can take up.
