Having a really hard time finding a security camera mount/adapter that will allow a camera to be mounted to a standard junction box. Essentially what I want to do is mount the camera similar to the way outdoor security lights are mounted to recessed junction boxes. The only thing that should be visible is the camera mounting bracket itself. Many of the high-end camera manufacturers make such mounts, but the mounts can get very expensive. I was considering using a weatherproof cover like this one as a starting point...
... and drill holes for the camera (three for the camera mounting screws and one 1" hole for the camera cables, but then I saw a reddit post where someone had done a 3D print of something similar, with the required holes, etc.
I don't have any 3D printer experience, but I've been thinking about diving in. Wondering if this would be a good starting point. Would this item (with the holes) be fairly simple to design and print? The one in the picture is 3/16" thick. Would a printed one the same thickness be strong enough to hand a 1 lb. bullet camera on a wall mount? I understand there are different filament types. I wouldn't want to use any filament that requires a means to exhaust the fumes out of the house. How long does it take to do the actual printing on something like this on a consumer grade 3D printer in the price range of $300 - $400?
Ira
Ira
