Just a promo here repost from Homeseer for 50% off.
Special Black Friday Coupon
HS3 (Full)
$124.97
(reg. $249.95)
HS3 (Upgrade from HS2)
$62.47
(reg. $124.95)
HS3PRO (Full)
$299.98
(reg. $599.95)
HS3PRO (Upgrade from HS2)
$237.47
(reg. $474.95)
HS3PRO (Upgrade from HS3)
$192.47
(reg. $384.95)HS3PRO (Upgrade from HSPRO)
$62.47
(reg. $124.95)
HS3-Pi2
$74.98
(reg. $149.95)
HS3-Pi-2 (Upgrade from Pi-1)
$19.98
(reg. $39.95)
Coupon Code: BM-50P
Attention HS3 Users:
Save 50% on HSTouch Designer
HSTouch Designer allows you to personalize your home automation system. Create your own project or modify existing projects as you like. Then, deploy those projects to your Apple or Android smart phones, tablets and other devices. Click Here to see how easy the designer is to use!
HSTouch Designer: $99.98 (reg. $199.95)
Coupon Code: BM-50P
50% off All HomeSeer Brand HS3 Plug-ins
Plug-ins are designed to let HomeSeer systems communicate with products from around the world. Save 50% now on plug-ins for Global Cache, Square Connect, WGL, DSC, Insteon, and more! note: 3rd party plug-ins excluded.
Coupon: BM-50P
20% Off HomeTroller S6 or S6 PRO
HomeTroller S6 controllers include HS3 or HS3PRO software and support all HomeSeer compatible plug-ins. These are advanced, high-performance systems.
HT-S6: $719.96 (reg. $899.95)
HT-S6-PRO: $959.96 (reg. $1199.95)
Coupon Code: BM-20P
15% Off HomeTroller SEL or SEL PRO
HomeTroller SEL controllers include HS3 or HS3PRO software and support all HomeSeer compatible plug-ins. Suitable for users with advanced needs.
HT-SEL: $339.96(reg. $399.95)
HT-SEL-PRO: $594.96(reg. $699.95)
Coupon Code: BM-15P
15% Off HomeTroller Zee S2
Our new latest "Zee" model is faster than its predecessor, has twice the memory, includes a built-in Z-Wave Plus certified controller module and works with a greater variety of products.
HT-ZEE-S2:$169.96 (reg. $199.95)
HT-ZEE-S2-EURO:$178.46 (reg. $209.95)
Coupon Code: BM-15P
15% Off SmartStick+ Z-Wave+ Interface
Improve your Z-Wave network performance instantly with our new SmartStick+ USB Z-Wave interface! SmartStick+ works with your HomeSeer system and supports all Z-Wave products.Upgrade easily from your existing Z-Stick!
SMARTSTICK+: $33.96 (reg. $39.95)
Coupon Code: BM-15P
15% Off Z-NET Z-Wave Plus Interface
Improve your Z-Wave network performance instantly with our new Z-NET Z-Wave interface! Z-NET communicates with your HomeSeer system using a simple network connection. With HS3's backup/restore feature you can easily move from your existing Z-Wave controller!
Z-NET: $127.46 (reg. $149.95)
Z-NET-EURO: $137.66 (reg. $161.95)
Coupon Code: BM-15P
I am a bit biased here as I have run Homeseer since 1998. (18 years now).
Today running Homeseer 3 Pro on an Ubuntu 14.04 64 bit box and Homeseer 3 Zee2 on a Rasberry Pi 2.
The Rasberry Pi 2 is POE connected in the attic with a GPIO ZWave Plus card and PiFace RTC shim trying to melt it or freeze it in the attic (temps up to 140 F in the attic).
Give it spin as the software runs with a 30 day trial. (It will run on Ubuntu, Wintel and iOS today).
HSDesigner will do consoles in Wintel, Linux, Android and iOS.
HS3 (Full)
$124.97
(reg. $249.95)
$62.47
(reg. $124.95)
HS3PRO (Full)
$299.98
(reg. $599.95)
$237.47
(reg. $474.95)
$192.47
$62.47
(reg. $124.95)
HS3-Pi2
$74.98
(reg. $149.95)
$19.98
(reg. $39.95)
Coupon Code: BM-50P
Coupon Code: BM-50P
Coupon: BM-50P
Coupon Code: BM-20P
Coupon Code: BM-15P
Coupon Code: BM-15P
Coupon Code: BM-15P
Coupon Code: BM-15P
