I have been using the 6 Channel Master Hub, in conjunction with digitemp monitoring software to read a bunch of 1820s.
Every once and a while, the master hub appears to lockup. In each case, the 'Channel 1' red LED gets stuck on, until I power-cycle the Hub. I'm logging temps 24/7 every 15 minutes, and it takes months for the lockup to occur, and I haven't found any pattern to it yet.
Looking at my own error logs, I see that the failure appears to initiate a series of 'Setting switch to main on state failed' errors as the logger iterates through the master hub channels, none of which succeed. On the very next read (15 minutes later), the failure becomes (and remains) 'DS2480b is not detected'.
I would look to the software first, but it does initiate a one-wire reset at the beginning of each read cycle, and it really looks like the hub will no longer respond to it once its in this state. the fact that I initially get the 'setting switch to on' errors implies that rs232 is working fine.
And like I said, its consistently a locked up LED on channel 1, and a power cycle of just the hub fixes the problem every time.
