8 or 12 channel IR controllable relay and a 12V 4A Power Distribution Module
shaurya
Hello,
I need to find a relay to turn on/off Monitors (12V DC 4A) with Infra Red. I intend to power these monitors thru Cat4(using all 4 pairs)..disucssed here (12V DC 4A on Cat5)
I also need to find a 12V power Distribution Module that can supply around 4 Amps per channel. Checked ElKproducts.com but couldnot find something that can supply 4Amps.
If there is such a product that can combine both the above mentioned functionality then awesome.
Please help.
Regards,
Shaurya
BraveSirRobbin
Moderator
http://www.elkproducts.com/products/elk-p412.htm
You will need something beefy for switching the four amps via relays. If you need an IR interface I do know the Ocelot will work with an external RLY8-XA add on box, but I'm guessing this route is probably more expensive than you want...
THIS site has some cool relay control boards, but nothing I saw was IR (just RF).
shaurya
Hello BSR,
This Elk can only power 3 outputs. I need something with around 8 outputs. Any other suggestion..
Great site for the realy boards. Will give them a call about IR relay. I liked your Ocelot route...Little hesitant..Read about the new product called FireCat...not sure if I should wait for it.
Found this 12 channel IR kit. $100 assembled. Any feedback?
Hello keepersg,
Great kits but too many moving parts. would like to have something basic.. Any feedback on the 12 channel IR kit I mentioned above.
Regards,
Shaurya
BraveSirRobbin
Moderator
Shaurya;
Not sure what you mean by this statement:
As far as the relay/IR kit board, I'm a little nervous (just a 'gut' feel) about the relays. I mean they rate the relay contacts at 10 amps then make a statement like this:
(never use these relays with more than 5 A of current if you want them last.)
Maybe I'm misinterpreting the specs...
The RLY8-XA Applied Digital add on for the Ocelot uses Potter-Brumfield (spelling?) relays (great brand).
