Well I think I have research this project a good bit and am close to ordering parts. My plan is to have a system that I can expand with time, however want to start with just a focus on the security side and then expand into HA.
So I want to minimize the amount of wire I have to pull through an older home so doing a good bit of wireless.
I plan to integrate the security panel with Insteon so was going to get this kit:
http://www.smarthome.com/128301D/INSTEON-Compatible-Elk-M1-Gold-Kit-and-ISY-99i-Controller-with-Dual-Band-INSTEON-Interface/p.aspx
Will be getting a second KP2 keypad for the bedroom and also getting the speakers to mount with them in the flush mount kit. Curious if anyone has tried mounting the 2-way speaker/mic in the flush mount kit?
This GE wireless receiver
http://www.smarthome.com/12839/Elk-M1XRF2G-Wireless-Receiver-Input-Expander/p.aspx
Was going to use this window sensor on my double hung windows
http://www.homesecuritystore.com/p-681-ge-nx-45060-670-95r-wireless-doorwindow-sensor-white.aspx
This door sensor on the wooden front door that has side lights so it has to be mounted to the top part of the door
http://www.homesecuritystore.com/p-1144-tx-1510-01-1-designline-recessed-doorwindow-sensor.aspx
The rest of the doors in the house are steel so I do not want to drill the doors. I was thinking I would use this plunger on them, will this ion work with the GE receiver I have listed above?
http://www.homesecuritystore.com/p-1376-plunger-g-ion-security-ge-compatible-wireless-door-sensor.aspx
This is the wireless smoke I plan to use, I only plan to use wireless smoke on the first floor due to issues running wire.
http://www.homesecuritystore.com/p-902-tx-6010-01-1-ge-wireless-smoke-detector.aspx
The wired smokes I plan to use, wanted one with a local sounder. After reading the Elk manual it seems 4-wire smokes you have more flexibility on the zones you attach them to.
http://www.homesecuritystore.com/p-65-449cst-esl-smokeheat-detector-with-sounder.aspx
For motion I am a little more confused what to get. I do have pets however they are normally confined to certain rooms when we are out so they really should not be an issue but would want pet immune to help reduce a false alarms if one should be loose for some reason.
For the wireless PIR sensors I was looking at this one (again is this compatible with the GE receiver?):
http://www.homesecuritystore.com/p-126-60-703-95-ge-iti-caddx-wireless-long-life-pet-immune-pir.aspx
For the wired PIR sensors I was looking at this one. Particularly I liked the size, my wife needs to approve anything that is visible so smaller is better.
http://www.homesecuritystore.com/p-736-pi6000-sentrol-motion-detector-with-pet-immunity.aspx
It is my understanding the wired motion sensors are better for HA usage since they do not sleep like the wireless ones, is this true?
I will also of course order some 4-conductor fire wire, any issue using the fire wire on the PIR sensors? Since I would probably order a bulk amount of fire wire I would have more than enough left over.
The wire for keypads and wireless receiver can I use Cat6 cable? I have plenty of it.
As for enclosures, the M1 kit includes a 14" can however that seems like it would be tight. I do plan to expand this system and the above is just my starting point. That said I was thinking of using the 14" can to hold the battery and transformer and getting another can for the system. Thinking a 28" would be sufficient, and recommendations on 28" cans?
I plan to run a dedicated power circuit for the security system would I be able to fit outlets within the 14" can? or can I get a transformer/power board that I can hardwire? Something like this http://www.homesecuritystore.com/p-404-elk-p412k-4-amp-12-volt-dc-power-supply-battery-charger.aspx
I know this is a big question, I have been lurking awhile and got a few answers already here. Just like to get some opinions and eyes on what I am putting together. Thanks again.
