I installed an ISY994i to integrate my Insteon lighting automation into my ELK M1G and use ELK rules to control my lighting. To do that involved exporting a file created by the ISY and importing it to the ELK. The imported file overwrites the X10 lighting entries in the ELK lighting table. The ELK rules work fine for controlling the Insteon devices via the ISY. However, it seems the rules are the only way you can control insteon devices from the ELK. ELK-RP software allows the rules to be written but you cannot test the rules, view the status of the Insteon devices, or manually change the state of an Insteon device, because communications with the ISY is suspended while RP has the ELK in programming mode.
The virtual keypads(M1toGo, and the embedded HTML M1 keypad page) also do not provide access to the lighting devices. They display all the other categories such as security sensors, temp/thermostats, outputs, etc., but once the import file is loaded from the ISY, the lighting section comes up blank in both these virtual keypads. As a result, you have no way to either view the ON/OFF status of the Insteon devices, or change the state of the insteon lighting devices from the ELK.
It can be done from the ISY, but the reason for upgrading from my prior HAI/HouseLinc configuration, is to consolidate my fire/security/automation into one control interface.
Does anyone know of any way to enable the ELK to provide status and manual control of Insteon devices?
