I've got some SA 1120W UBP rocker switches to give them a test run. I'm using them to replace the buggy smarthome switchlinc-relay switches (don't get me started about the firmware bugs in those!). I'm using them with with some instant-on electronic ballast fluroescent lights.
With the switchlinc-relay switches, they did indeed turn on instantly. With the 1120W's (in snap-on mode!), there is nearly 1 second latency between the lights turning on or off in response to the rocker being pressed.
I've triple checked with UPStart that they are programmed into snap-on mode. If they are in fade mode, you can see the difference (the lights "brown out" and flicker etc).
Also, the indicator light changes almost exactly at the same time that the controlled lights turn on or off.
Have I missed something or are they supposed to be this slow to respond to the rocker? I could understand delays in response to a command being issued, but the actual rocker switch?
