I've been reading HA topics here for about 6 months now and am slowly starting to untangle the bazillion questions I have about how to introduce HA into my house without going bankrupt or getting divorced.
One of the things that's kinda frustrating is that I'm trying to do this in a 4000 sq ft house built in 1975. There's a basement under most of it but no attic over the "A-Frame style" main living area.
Almost all of the beginners guides and How-to guides on HA and wiring seem to focus on planning and implementing HA in new construction. Is anyone aware of any good resources that have information on how to do HA as a retrofit?
I've swooned with envy at the setups some of you have. I desperately want to have the kind of smart HA I see folks here talking about. I would love to have RFID tell my house which car just pulled in or motion sensors that turn on hall lights as a person walks or a mailbox that announces when the mail arrives.
I do have a pretty good wireless computer network in the house with music streaming from a dedicated computer to my main amplifier via an apple airport express. I have some lamps controlled by Insteon LampLinc's. I have a USB PowerLinc though so far I don't have much for it to control and haven't used it.
I really like the Insteon technology and have purchased several Switchlinc V2's to use to control lighting. Unfortunately it turns out that most of my wall switches don't have neutral wires. At least as far as I can tell since none of my wires use the nifty color codes thast get referenced all the time. All the wires in my house are black and white. I did find one switch in the dining room that =might= have a neutral wire. It has a couple white wires tied together with a wire nut that don't go to the switch. Since the wiring appears to run from that switchbox up to the outlet in the loft that has my computers on it (at least, the computers shut down when I turned off the breaker to the dining room light) it seems like the extra white wires might be a neutral but how do I tell?
The thought of trying to run neutral wires all over this house through the existing walls is incredibly daunting. I've seen a couple references about the possibility of (cough) connecting the ground wires instead of a neutral wire to the SwitchLinc's neutral but can't tell from the (ahem) non-recommendations if that is safe. I really don't want to burn my house down.
Anyway, the more I read the more confusing it all seems to be. My most basic questions seem to be:
1) Have any of you guys successfully retrofitted a 30 year old home with HA? How did you go about it? Are there any good sources of information on the process that a non-electrician can understand?
2) Should I even bother thinking about Elks and Stargates or should I just use one of my many PC's as a controller? I've been programming for about 25 years so I'm comfortable with PC's but M1's do seem mighty cool. How hard is it to incorporate an Elk into an existing home without existing structured wiring?
3) How do I tell if a wire is neutral without reference to a color scheme that is non-existent? The one wire that seems to be a neutral appears to be grounded since I get a reading off the voltmeter when I touch one lead to the line and the other to the unknown white wire. But how can I actually tell?
4) Are there any safe (code or non-code/ recommended or non-recommended) options if I don't have neutrals at my switches? I see that the Leviton motion detectors connect to the ground wire instead of the neutral but, hypothetically speaking and without any recommendation, would it hypothetically be safe to do that with a Switchlinc if I can't run a neutral to the box?
5) How the hell do you get your mailbox to talk?
Bill
Bill
