adding ir receivers to nuvo concerto
forgets
so I've got all 6 keypads of the concerto mounted in areas that the g/f likes, which in the master bedroom is slightly out of sight of a remote, however she wants to be able to contol it via remote from bed, so I figured I'd mount a ir receiver to the ceiling, which I've done, but now I'm stuck, I want that ir sensor to control just the master bedroom zone for the concerto..
so how can this be done? I believe the concerto system operates at 24v so I can't power the ir reciever from it.. (its a speakercraft) , but can I wire a rj45 into the back of the secondary port in back of the master bedroom keypad with just the ir data and ground connections ? i can power it from normal 12v from the speakercraft connector .. though I think I read that the concerto strips out some data from the ir, or uses some odd frequency, but I'm lost as to how that might be a problem as I'm using the concerto remote to control the concerto, ill try calling kilowatt tomorrow, but I'd appreciate any insight in case someone else has already attempted it, thanks!
opie
I remember a similar situation another integrator had and I believe the final solution was that he used an RF remote and receiver at the Grand Concerto and then spliced the cable (similar to the way a mid-span injector for POE would work) to put the IR data onto the cable for the zone he wanted to control. The pin-out for the control pads is on page 7 of the GC manual. You should be able to do the same at the control pad location. You won't have IR at the keypad anymore but maybe that won't matter.
I am not sure if you can use the NV-IG8LSA port on the back of the control pad?
Please post what Professor Kilowatt says, I may need to do this and am curious to hear his ideas.
EDIT: Clarification
