ADT -> Caddx 8e - What do I need to get?
SpaceCowboy
So a few questions for all alarm gruru's out there.
I currently have an ADT somethingerrather system and am pulling it out in favor of the Caddx NX-8e connected to my HomeSeer system. A few questions:
1) Can I use the existing transformer, battery and RJ Cord/Block?
2) Can I use the existing siren?
3) Can I use my exisiting door and motion detectors?
I'm assuming it will all work but may have to check if the transformer is to the correct spec? Everything else should be a no brainer eh?
I was looking at purchasing one the FastPack kits but may not need everything and could save some $$ by ordering the board, cabinet and panels only.
Thoughts? Wisdom?
Thanks!
theAberdeenKid
The system is probably the ADT SafeWatch Plus RF. Are any of your devices wireless? I know ADT is big on installing wireless devices. How old is it?
SpaceCowboy
The system is about 5 years old. I think it was some sort of safewatch system but doesn't have any wireless devices (my home was pre-wired). I think I'll open the system box tonight and see what I can find out inside (while I own the system, they won't give me a key to the box even after I've cancelled my service).
AutomatedOutlet
I think you'll be able to re-use most of that. For the transformer, you'll just have to check the specs on it.
I just recently did a similar thing in my house. I have the new Caddx system installed but still need to add the resistors to make the system operational.
I reused my contacts, motion sensors, and siren. My battery and transformer were old so I replaced them.
SpaceCowboy
So it turns out it is a Safewatch Pro 2000 system (Q: Was this a Ademco OEM board?) with RF capability if used with an external module and I even found the programmers guide and installers code inside (not that it's of real value to me since I still want a serial output). The transformer and battery look like standard specs so I think I'll re-use them for now (q: How long before one should replace the battery?).
So Martin,
Could I ask for your help in picking out some pieces of NX-8e gear?
I think I'll need a NX-8e board, 2 keypads, software. Could you email or PM me some costing info? Thinking about the 1192 keypads as I'd like LCD for sure.
I'd like to try and write a NX-8e "How-To / HomeSeer" guide as I go through this that everyone can build off of (since I'm sure my system is not as nearly complex as some others have).
Thanks everyone.
jlehnert
If the battery is 5 years old, go ahead and replace it. It may have a few years left on it, but why take a chance on it croaking while you are on vacation? Replacements are cheap (<$20).
Yep. Common Borg tactic. They won't give you the installer code either, so you lucked out in finding it inside the can.
