OK...so I'm like me2. Both of our first posts are seeking guidance on building our dream homes. Except for me...money DOES matter.
My wife and I are both in our mid 30s and we're building a 4k sq ft two-story house on the family farm. (Moved back home after living many other places...ISO the simpler life.) We will be living in the home for approximately...forever.
Of course...I want it ALL and can't afford to have a pro do it. (Unbelievable what they get for these kinds of features.) Fortunately I'm a techie with a computing and data networking background...so I can do much of it myself. My approach is to set a $10k construction budget to accomplish 2 things:
1. Make sure the home is wired as well (flexible, extendable, etc) as possible.
2. Implement as much of the desired features as I can initially and enhance over time.
Electrical, phone / data / video, wiring has it's own reasonable budget so the $10k is for materials and labor outside the scope of "normal" wiring (ok...i know that's completely undefined) that is dedicated to HA.
My priorities:
1. Home security
a. Door / window contacts monitored
b. Motion Detection
c. Smoke alarm monitoring
d. Cameras
e. Remote monitoring
2. Lighting status and control.
3. T-Stat status and control.
4. Whole House A/V integration with Home Theater
5. Lawn sprinkler status and control
6. MANY miscellaneous pet projects for the future. For example:
a. main water valve status and control
b. exterior wind speed status (control would be COOL!)
c. drape status and control
d. wife status and control B)
The priorities get mixed up a little bit because of the phasing approach. For example...it's more important for me to WIRE for audio than it is to IMPLEMENT lighting control.
Design principles:
1. All status and control must be able to be presented via a web interface.
2. Anything that is controllable must be programmable (IE able to be scripted).
3. Wireless is for mobility only (unless you CAN'T wire it)
4. More integrated is (almost) always better.
I have downloaded the planning spreadsheets from the "wiring your new house 10x" series here. It will definitely help in my planning and communication with the electrician / cabling guy.
I think I'm mostly sold on Elk:
1. Price
2. Solid feature set
3. Flexibility
4. Support / DIY acceptance
For HVAC i will have 2 Trane multi-stage heat pumps.
So now a few questions:
Q1. Can I have a hardwired lighting system controlled by the Elk? All the info I see is done with PLC stuff.
Q2. Any direction on which T-Stats to use?
Q3. What to A/V integratioin? I haven't looked into A/V integration much even though I've always done my own Home Theaters and all cabling it's always been a separate system with no real integration to other components. Unless you count caller ID.
Q4. Anybody have experience using PLC in a Rural area? The one Pro shop I talked to steered me away from PLC because he said the power out in the country wasn't clean enough. Not sure if this is just a sales job...
That's it for now. Any help is appreciated - I think I've found an awesome forum here (been lurking awhile). I'll share my experiences with you all. Home is almost fully framed so I'll need to set my direction soon...
My priorities:
1. Home security
b. Motion Detection
d. Cameras
Design principles:
1. Price
3. Flexibility
