johnnynine
Has anyone had any success using an insteon dimmer switch with a ceiling fan?
The insteon documentation indicates that SOME ceiling fans may not be compatible.
I saw that a 3-Speed Fan Control Switch was in the works (and probably a year out) and am wondering if I need to wait.
Johnny
To reduce the risk of overheating and possible damage to other equipment, use SwitchLinc Dimmer to control 110Vincandescent lamps only. Dimming an inductive load, such as a fan or transformer,could cause damage to the dimmer,the load device, or both. If the manufacturer of the load device does not recommend dimming, use a non-dimming INSTEON switch such as SwitchLinc V2 Relay. USER ASSUMES ALL RISKS ASSOCIATED WITH DIMMING ANINDUCTIVE LOAD.
Johnny
