I just got A/C installed and decided to go with a heat pump instead of just an A/C unit. The interesting part of it though is that at certain temperatures I need to have the system switch over to use the gas furnace for heating instead of the heat pump. I have an RCS TR40 thermostat so that I can integrate with the ELK. problem is, it does not support dual fuel systems and switching over like that. I talked to RCS and they confirmed that
They did suggest that I may be able to use a relay or two, integrated with the ELK to setup the system to switch over to the furnace based on a temp probe. They did say that they had heard of people doing this both automated and just with a manual switch.
So, is there anyone on here that has setup a dual-fuel heating system or has some advice on how to go about doing it? I'm thinking I'm probably fine with a manual cutover b/c the only time I really need to switch to furnace heat is when the temp is below 40 degrees (maybe even lower), and I'd be happy to just use the furnace alone at certain times of the year. If anyone can help out with their own setup and/or some wiring diagram info I would greatly appreciate it. The system is up & running now with the heatpump providing both heat & cool, but by next November or so I'll need to be able to switch over.
