anyone try exceeding 10' for a prox reader?
IVB
Wondering if anyone has tried pushing the bounds for a prox reader. I foolishly bought a prox reader already w/o RTFM as I have a location that would be perfect for it, but it's probably around 15' or so. It will be a royal PITA to run wire there, and moving the ElkKP isn't an option.
IVB
Excellent, that sounds promising enough to at least try. I'll post back here with the results.
Thanks for replying so quickly.
gatchel
10'???
Was this an Elk distance or the manual of the prox reader
Most of the access systems we deal with have a wiegand prox maximum distance of 500 feet or so. I'm not sure if this is an Elk limitation but just remember to run the line away from electrical noise or high voltage sources.
brotsten
IVB said:
The Elk manual says 10' max for the prox reader.
I am planning on using a couple of the external prox readers. I had no idea they had that kind of range. Does that mean if I have a card in my wallet and I get within 10 feet or so of the reader, the system will disarm?
What happens when you are exiting and setting the alarm, do you need to use a rule to ignore the prox reader?
Brian
Mike
No I think they are referring to a reader connected to a keypad, not the sensitivity of the reader itself (which will only be a few inches, 3 if I remember correctly).
brotsten
That's what I thought..... :D
Hey, where's that light bulb emoticon?
Brian
15' would be really cool though. Back to the RFID threads.
gatchel
Yeah...10 feet would be cool without an active repeater.
Maxi-Prox eat your heart out!!!
