Anyone using Rain8UPB?
dbinaz
How in the heck do you get this thing to work properly? I did the config and set it all up, but only 2 of the valves turn on and none turn off no matter what. I am only using their demo program to test right now tho I do have mcsSprinklers setup but I believe it's the same issue.
Derek
robolo
Derek,
I set up a Rain8UPB with an extension module for 10 zones last week and it is working correctly. I did have trouble with the demo program reading the zone status so I simply used the demo program to turn zones on and off but then I confirmed zone status with a voltmeter. This confirmed all was working properly. I then set up ELK M1 rules to run the Rain8 via UPB signals.
Michael McSharry
If you run the Communication Check from the Rain8 page of mcsSprinklers it will give you a better picture of how the module is responding to the commands. Also make certain you do not have overlaping UPB DIDs with other modules on your network.
