/archive/j/news/2011/4/elknavigator.jpg
ELK has announced a new touch screen based keypad, and a new 2-way RF platform for the M1/EZ8 product line.
The 3.5" touchscreen is called 'Navigator', can be customized by installers, and connects directly to the RS-485 databus, meaning it can replace the existing keypads.
The new 2-way RF technology will offer increased reliability, by actually confirming if a command was successfully sent/received, and be more resistant to noise/jamming. Check the press release below for more information.
Click here to view the article
- Two way communication at 902 to 928 Mhz
- Frequency hopping spread spectrum
- Acknowledgment with each transmission so transmission are very short compared to one way systems
- Variable power output so only the power needed to get to the central receiver is used
- RSSI signal level reporting
- RS485 data bus receiver(s) to the M1
- Multiple receiver operation for expanded area reception back to the M1
- 3 types of door and window transceivers, small, medium, large
- PIR motion detector
- Smoke detector
- Glass break detector
- Movement detector
- 5 button keyfob
- Temperature and humidity sensor
- 2 channel stand alone receiver
- 8 channel stand alone receiver
- Sniffer RF traffic to USB
