Frederick C. Wilt said:
That would be an ASCII to Z-Wave device.
Per the note below, it's a 2-way device per the graphic with arrows in both directions!
NeverDie said:
According to the linked-to press release it's two way, so you're both right.
Will it also double as the new z-troller?
The new Z-Troller is still in development but should be ready by year's end.
Well I'm glad to see that no one at HomeSeer is the least bit confused.
I wasn't until your message!
What do you mean?
az1324 said:
Is it any different from razberry?
Yes, this new module is really for companies that do not support Z-Wave now, but want to... and don't want to spend the enormous amount of time and money necessary to do a decent job of it. The module accepts simple ASCII commands and spits out Z-Wave... then receives Z-Wave status updates and spits ASCII back to the controller.
