[Article] Promixis announces new network-enabled IO module
electron
Administrator
Staff member
/archive/j/news/2011/8/pio1.jpgPromixis announced a new network-enabled flexible I/O module (PIO-1), allowing you to control devices such as TV's, projectors, home automation gear, relays and more, using a very easy to use ASCII based protocol. The unit sells for $199, and is available now from the Promixis store. Key features:
  • 2 Serial outputs
  • 4 IR Outputs
  • 1 IR Input
  • 3 Relays
  • 2 bi-directional digital ports
  • 8 (up to 13 in custom builds) internal lines with 3 available PWM outputs (expansion boards available)
  • Web configuration interface ( default password: cookie, leave user name empty )
Click here to view the article
