kurtmccaslin
Recently my detached garage was hit by lightning. Here was the damage:
In the garage:
1 Omni Pro expander module
1 network switch
2 garage door openers
1 motion detector
2 electric window operators
2 UPB wall switches
1 solar panel monitoring system
In the house:
2 keypads
1 network switch
1 water circulating pump
1 Amazon Fire TV
I have lightning rods installed on the house and separate garage.
I have a whole house surge protector installed on each of 3 sub panels. Those seemed to work because the lightning did not travel from the garage to the house on the power line. However, it did hit the house through the data wiring on the Omni Pro, and on my wired ethernet. It also seems that I got a jolt through the water system as the water circulating pump was the only damaged item in the house which was not on a low voltage line.
I have secondary surge protectors on my automation panels, but not on the garage door openers or on the water pump.
There is a cat 6 cable running 140 feet from the house to the garage. Shielded burial grade wire in conduit. The shield is not grounded, but there is a ditek surge supressor on both ends. I know that the shield should be grounded but just have not gotten around to it. The network switch at both ends of this wire was fried.
There is an unshielded 1 pair data cable from the Omni pro in the house to the expansion boards in the garage. There is a ditek surge supressor on both ends grounded to the building ground on both ends. I lost one expansion board (out of 4) and 2 keypads (out of 4) on my data network. Strange, but the keypad in the garage still works.
There is a shielded cat 6 cable from garage to the house. This is my DSL and phone line. This cable is not grounded and does not have a surge protector on it. Nothing was damaged on this line.
I have a ground wire running from the Omni Pro to the expander module, and it is tied to the house ground on both ends.
Here are my thoughts:
- I will upgrade my network to fiber between the house and garage. I was planning to do this but now it has a higher priority.
- I will put surge protectors on the garage door openers and on my water circulating pump.
- I plan to replace all of the Ditek surge protectors because they failed to protect the system. (but may have mitigated the damage?)
- I plan to earth ground my shielded cables at the house end only.
- I will earth ground the Omni panels at the house end only. (cutting the earth ground at the garage)
The only earth ground that is available to my panel is the building ground. The building ground is a Ufer ground buried in my slab, but it is about 12 feet from my panel via the 12 ga wire to the panel.
Any other ideas on how to protect against this kind of damage? My house is on a hill, so this could very well happen again.
In the garage:
1 network switch
1 motion detector
2 UPB wall switches
In the house:
2 keypads
1 network switch
1 Amazon Fire TV
