Batch File Help
Squintz
I know batch files wer not reall designed to do math but I see complex examples on the net which makes me thing I can do simple math.
I do a math problem at work very often and get tired of using a calculator. So I want to be able to click a batch file icon on the desktop and type in a value and to the following problem.
Result = (InputValue/17.7777) * 1.0186
Can anyone here write this for me? I can't seem to get anything to work. If not I will just write in in C# later tonight.
CollinR
You don't have excel?
Isn't there some freeware equivalent?
Yup Excel is the one to use. :lol:
You might also look at open office, they have a spreadsheet app too.
Also MSAccess can do the calculation and store it for reference if desired.
Squintz
I do have excel but that takes too long to open for what I need it for. I need to enter a number into a radar system and the number I am given is in Degrees and I need it in MRAD. Which is what the above equation is. I do the problem about 20 times a day or about 2 or 3 times an hour.
The computer I am using is really slow and I figured the quickest smallest application would be a command prompt utility which I clicked right on the desktop and it asked one question and spit out the answer. Then I would just type it in the Radar applications.
Right now I just use the windows calculator but I get tired or remembering the equation. It would be one less thing I have to think about while processing data
Rupp
Here's a real quick app but it doesn't have any error checking.
  • CommandLineInput.zip
rocco
Hi, Squintz, I use this:
http://joshmadison.com/software/convert/
It is very fast to use. If the angle tab does not do what you want (is MRADS milli-radians?), then there is a "custom" tab where you can add your own conversions.
The angle tab does revolutions, radians, gradients, degrees, minutes and seconds.
Rupp
Here's an update that checks to see if the input is a number and hitting return auto selects the calc button.
