RandyKnight
Here's a dumb question. If I want to put a load bearing Insteon (or UPB) switch in one of the SA pedestals, how do I wire it? It just has the 2 wires from a dual prong plug. Is one neutral and one hot? What about ground? Ground it separately? For this, I just want to be able to hook up a switch for programming, etc.
The second part of the question is how do I add a load to it. The idea would be to mount a bare bulb on the bench that I could tie the switch above to. Would that just be a single wire from the bulb to the switch and then a hot to the bulb as well?
Thanks. As you can tell, my background is high tech geek stuff, not household electrical.
