NeverDie
Is there a good quality low-power home alarm system? I'd like something that could run for up to a month on battery power alone and still function if the mains went out for whatever reason. If I assume an average draw of 1amp at 12v, then to cover 30 days I'd need a 720ah battery, which would get rather pricey. Hence, an alarm system whose average consumption was around 100ma would be a lot better, and anything lower than that would be better still. Is there an off-the-shelf product which can do that?
Presently I have a Vista-20p hardwired system, and even just the keypads alone draw a lot of power.
I realize solar power backup might be a viable alternative to a massive battery bank, but if I can avoid having to rely on such a thing, then so much the better.
Any suggestions?
If not, then the next fallback might be to put together some kind of arduino based system, since, for example, an atmega328p can sleep while consuming just 100na while waiting for an interrupt, so I suppose I could use that as a front-end and wake-up a regular alarm system from there.... Still, I can't be the only person in the world who wants this, so I thought I'd ask first.
Any suggestions?
