I have 7 Smarthome X10 dimmers that I really like. I still have about 10 X10 brand dimmers that I want to throw awy and replace with something better. X10 is ok in my house, but some areas are not reliable. My plan is to keep the 7 expensive Smarthome dimmers I already have and add Insteon in the bad places.
I have the Smarthome 1132CU (I think) USB/PC controller. I use the Smarthome software that downloads into the controller. I use it for macros and timers.
I also have an X10 ir reciever to send codes to run macros and turn lights on and off.
One problen area is a lamplink that is intermittent. If I use the ir or the PC it always works, but the keypadlink won't always control it. For example I was thinking about replacing that with an Insteon lamplink. But I would need a translator.
Any thought os how to control things?
Even if I could afford to replace everything with Insteon, I would still need to use X10 for IR.
Once I have all Smarthome devices I won't need macros, I can just use the scenes.
Is it possible to have the keypadlink send an X10 command, and all X10 switches respond to that, and then the when the translator receives that X10 code have it convert to Insteon and send it to any Insteon devices?
I'm open to any suggestions now
thanks,
~Jay
thanks,
~Jay
