Camera Question
68sting
Long story short do to a shipping error I have the choice between 2 cameras. I'm going to use this as a front door cam(see pic).
CBC Pro-Pak outdoor housing kit HWB2-84A9 with Ganz ZC-NH403N - $215
LENS MOUNT CS-Mount
IMAGE SENSOR 1/3” Ex-View IT CCD
EFFECTIVE PIXELS 768(H) X 494(V)
SCANNING SYSTEM 2:1 Interlace
SCANNING FREQUENCY 15.734hHz (H) /59.94Hz (V)
SYNCHRONIZATION SYSTEM Internal/Line Lock
HORIZONTAL RESOLUTION 480 TV Lines Day Model / 580 TV Lines Night Mode
VIDEO OUTPUT 1.0V (p-p) /75 ohm, Video 0.714V (p-p), Sync, 0.266V (p-p)
S/N RATIO More than 50dB (AGC OFF)
MINIMUM ILLUMINANCE 0.06 lx. (F1.2/50 IRE) ,0.03lx (F1.2/30 IRE): Night mode
GAMMA 0.45/1.0
AGC 38 dB max.
ELECTRONIC SHUTTER Auto or Manually Selectable (1/60-1/100,000)
BLC On / Off (6 selectable patterns)
WHITE BALANCE ATW / Manual
COMMUNICATION RS485 two way communication
ON SCREEN DISPLAY (OSD) Camera ID (000-999 address), Various menu setting
OPERATING TEMPERATURE -10° to + 50° C
STORAGE TEMPERATURE -20° to + 60° C
HUMIDITY 80% RH Max. (No Condensation)
POWER SUPPLY 12 VDC / 24 VAC Auto Switching
POWER CONSUMPTION 4.5W
WEIGHT 450g
or
American Dynamics ADCA470CA with housing and mount-$80
1/3-inch interline color CCD
Digital signal processing
470 TV lines resolution
0.7 lux low light sensitivity
Night-Saver™ mode offers color to monochrome switching ability to enhance low light images
DVR-Saver™ mode saves DVR hard drive space
Automatic detection of DC or video auto iris lenses
C/CS mount
Aperture correction
Automatic electronic shutter (AES)
Automatic gain control (AGC)
7 backlight compensation zones
Sync options: line-lock or internal
24 VAC or 12 VDC input
Internal isolation transformer
Low power consumption
What would be the best for my location and what's the best deal?
CollinR
The Ganz is the better deal out of those two however I would just use a BW bullet and save the $ or get 2 angles going and still save $.
EDIT:
Your location sucks BTW, if at all possible get the camera lower, closer to eye level. A smaller camera makes this much easier to pull off.
68sting
I agree the angle sucks but asthetically there's no other place to put a camera. Any paticular camera you had in mind? Price?
Lance
68sting
Hello Collin
I sent a couple of pm's awhile back and haven't heard back. Did you get them? My sent folder is always empty for some reason so I don't have a way to track my pm's.
Lance
