I recently installed two HAI Omnistat2 and connected them to a Elk M1XSP which is connected to my Elk M1G. The thermostats work fine as stand-alone units but will not communicate with the ELK no matter what I try
Below is a summary of what I have done so far to try and get it to work. I have read through both manuals many times and did extensive searches on the forum here to see what I might be missing, but I can't seem to figure it out.
Any help on how to troubleshoot what might be the problem would be very appreciated.
ELK M1XSP
1) M1XSP has address DIP switch set to 1, Mode set to 1010, Baud set to 110 (2400), JP3 is set to 232, JP1/JP2 are not jumpered, JP5 is jumpered
2) M1XSP shows up properly in Enroll/Update screen and has the firmware updated to 70.0.2
3) The ELK-WO46A serial cable is connected to a terminal block
4) Made sure that A and B wires for connection to M1DBH are correct (I don't think it would enroll properly if they were swapped)
5) I only have one M1XSP and it is set to address 1. The only other item set to address 1 is a keypad, but that shouldn't be an issue because it is a different type of device and the Elk manual states that different devices can have the same address
6) Thermostats show up on keypad and T01:Not Enabled and T02:Not Enabled
7) The only weird thing is that when I updated the M1XSP to 70.0.2, the 'Check For Updates' screen said the HAI Omnistat firmware was 30.0.2, but the description said it was 70.0.2 and shows up as 70.0.2 after the update
Omnistat2
1) Comm jumper J8 is removed from the back of the Omnistat 2
2) Omnistats are homerunned to the terminal strip that the serial cable is connected to using four conductors of a CAT5 cable (blue, brown, green, orange)
3) Made sure that 'black' and 'red' wires are correctly placed in Omnistat
4) Addressed as 1 and 2
5) Communication Mode-Serial, System Baud-2400, Expansion Baud-2400
ElkM1G
1) I was going to update to the latest Firmware 5.2.10 but it says that it is a newer firmware than my version of ElkRP recognizes?!? It will let me install, but says that some functionality may not be available with the version of ElkRP that I am using.
2) I updated ElkRP to 2.0.16 and it still says that the firmware is not recognized by ElkRP. Tried rebooting computer and got the same thing
Does anyone have any ideas of what I could try to get these thermostats communicating?
Thanks!
ELK M1XSP
Omnistat2
ElkM1G
Thanks!
