You've been granted Beta access to this site, allowing you to explore some of the new features while they're still under construction. More information can be found in the Beta forum.
I use 5 of the Lightolier fan switches and they work perfectly. They have low medium and high and can be adjusted dynamically as the night temps change.
DeathtoToasters - aren't you using UPB? (I think so, but may have my people mixed up)
If so, I'm using UPB with my fans - but in a relay fashion (on/off), no dimming. I use the fan switch to set the speed (lo, med, hi) since I rarely change it... and the UPB switch just turns it on or off. Works fine...
