Chat Room ???
jazappi
I havent been able to get into the chat room for over a week now, I get a Unable to Connect: null error.
Any suggestions?
electron
Administrator
Staff member
I just tested the applet, everything seems to be working. Did you change anything (browser, service pack, etc.)? Are you behind a firewall?
WayneW
it works fine for me, but I normally use mIRC. I assume you are using the web/java client? I know I cannot chat from work, I have to connect to home, then chat from there.
unrealii
Any suggestions?
This happens on my computer too. I have yet to figure out what's causing this.
electron
Administrator
Staff member
have you guys tried mIRC? I know jazappi has been online before, so it has to work!
jazappi
Sorry it took so long to get back. So here is the update. SysAdmin says they are not blocking anything, I have turned off the windows firewall and still isn't working.
I took my laptop home, tried there, still getting the null comment. I was using the webclient, now I can't.
So that gives more details of whats going on.
Let me know what you think.
Joey
electron
Administrator
Staff member
mIRC is the only thing that will tell me what the exact issue is since the error messages make more sense.
unrealii
I tried the client...unable to connect to irc.marstracker.com port 6667
Here's my traceroute (dunno if this helps):
Tracing route to irc.marstracker.com [24.59.64.234]
over a maximum of 30 hops:
1 10 ms 24 ms 5 ms cpe-70-93-110-41.socal.res.rr.com [70.93.110.41]
2 11 ms * 15 ms 10.32.64.1
3 9 ms 9 ms 15 ms GIG2-1.HNBHCA1-RTR1.socal.rr.com [24.30.161.169]
4 29 ms 14 ms 8 ms SRP2-0.ORNGCA1-GSR2.socal.rr.com [24.30.161.157]
5 18 ms 8 ms 9 ms SRP2-0.ORNGCA4-GSR2.socal.rr.com [66.75.161.189]
6 17 ms 16 ms 13 ms SO-0-1-0.LSANCA1-RTR1.socal.rr.com [66.75.161.26
7 29 ms 10 ms 11 ms so-4-2-0-0.gar2.LosAngeles1.Level3.net [4.78.202
.25]
8 11 ms * 13 ms so-0-1-0.bbr1.LosAngeles1.Level3.net [4.68.96.81
9 76 ms 86 ms 76 ms so-1-0-0.mp1.Philadelphia1.Level3.net [209.247.8
.69]
10 81 ms 76 ms 112 ms so-0-0-0.gar1.Philadelphia1.Level3.net [209.247.
9.230]
11 119 ms 96 ms 95 ms TIME-WARNER.gar1.Level3.net [63.209.188.2]
12 101 ms 96 ms 105 ms pos13-0.syrcnyspp-rtr01.nyroc.rr.com [24.92.224.
22]
13 103 ms 101 ms 100 ms srp5-0.syrcnyspp-rtr04.nyroc.rr.com [24.92.224.1
40]
14 95 ms 98 ms 95 ms srp-1-0.syrcnymph-ubr1.nyroc.rr.com [24.92.227.2
10]
15 1448 ms 122 ms 120 ms fas2-0.syrcnymph-ubr01.nyroc.rr.com [24.92.225.2
06]
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * ^C
unrealii
www.marstracker.com works for me. I tried going directly to irc.marstracker.com and I received this message after the applet loaded:
[12:42] *** Failed to launch Ident server : access denied (java.net.SocketPermission localhost:113 listen,resolve)
[12:42] Connecting...
[12:42] Unable to connect : Software caused connection abort: connect
zack
Try opening port 113 in firewall?
