chucklyons
I happened upon this CHEAP (~$100) tablet on eBay' 7" MID UMPC Netbook Tablet Touch Screen WindowsCE C068'
I thought I'd give it a try.
Specs:
7inch Touch Screen EPC Specification CPU AK7802,266MHz
Internal Memory DDR 64MB
System Windows CE5.0
Hardware NandFlash 1G
LCD Display 7″TFT digital screen,16:9 widescreen
Display Screen Resolution 800*480
Online Support Including 10M-100M net card and
Net Interface 802.11B /G wireless net card
Card Reader/storage Device SD/MMC card,U-disk
I/O Port DC In power socket
Mic In head socket
Earphone earphone socket
Ethernet RJ-45 port
SD/MMC clip slot
1 line USB2.O Host connecter
2 line USB1.1 Host connecter
Audio Frequence Inlay 0.5W*2 stereo trumpet
Inlay monophonic recording
System Status Of LED Power pointing
Charging status
Number lock
Caps lock
Rolling lock
Battery 1800mAH,7.4V lithium ion battery
Endurance Ability WIFIunfold:5 hours
WIFI close:7 hours
Power Adapter AC100-220V 50/60HZ Input,DC9V 1.5A Output
Size 213.5mm*141.8mm*30.8mm
Colour Black/White
Weight About 0.37KG
The 64MB RAM is a bit tight - I've contacted the manufacturer about upgrading. Some of the screen prompts appear in Chinese. Still checking out battery power.
It took a while to get the SYSConnector to load, using the ARM connector. End of story? It works! If i can get the RAM upgraded and verify the battery, I would recommend this. Full Premise functionality (I had to revert back to 800x600 - they do have 1024 versions available). Did take a long time to receive -
As always, follow my input at your own peril!
Specs:
Mic In head socket
Ethernet RJ-45 port
SD/MMC clip slot
Charging status
Number lock
Caps lock
Rolling lock
WIFI close:7 hours
Colour Black/White
Weight About 0.37KG
