I just discovered this site
CCTV Speciality
This seems like an unbelievable price $139.99 for this camera with a 3.6mm lens and 23 LEDs. I may have to call them tomorrow (Lake Worth, FL) to check this out. They also seem to have a DVR card capable of either 20fps per channel (at $155) or 30fps per channel at $225 - yes per channel so I believe.
Color Infrared Sony Super HAD CCD Day/Night Camera with 23 LEDs
Furnished complete with Lens, Mounting Bracket, and Power Supply, this tiny 4 inch easy to install camera will exceed all expectations. The Sony Super HAD CCD with 480 Lines of High Resolution will deliver a perfect picture in the day and the high 23 LEDs will bring you a professional quality picture in complete darkness. This camera is weatherproof and can be used for outdoor application, has the ability to see in 0 Lux.
SONY 1/3" Super HAD CCD
Waterproof Housing
Powerful function : AGC control: Auto
Lens: 3.6mm or 6mm Lens
Specifications:
• Image Pick-up Device: 1/3" SONY Super HAD CCD
• Video System: NTSC
• Pixel:NTSC:512(H)*492(V)
• Horizontal Resolution: 480TV Lines
• S/N Ratio(AGC Off): =48dB
• Video output frequency: 1.0Vp-p/75 Ohm
• Lens Image Function: Standard / Lens Image
• Electronic shutter time: 1/60-1/100,000second
• Minimum illumination(F1.2): 0.8 Lux(AGC ON)
• AGC Control: Auto
• Backlighting compensation: Auto
• IR Light Distance: 15-20M
• Power Supply: DC 12V <150mA
• Power Consumption: DC 12V,120mA
• Operation Temperature:-20c~+50c?
• Color Waterproof Day & Night Camera
Availability: Usually ships the same business day.
SPE-218 List price: $229.99
Your Price: $139.99
Lens: 3.6mm
CCTV Speciality
Waterproof Housing
Specifications:
• AGC Control: Auto
Your Price: $139.99
Lens: 3.6mm
