Cutting and Pasting Rules from ELKRP
Spanky
It is not obvious on how to cut and paste the Rules located in ELKRP. Here is a method:
From ELKRP select:
Rules,
Click the PRINT button on the top toolbar,
Select This Account,
Select Preview,
Only check the RULES selection,
Select OK
Right Click and select Export
Select Text and Disk Files
Enter File name
The file should have text of the Rules that can be cut and pasted.
Happy M1ing!
jml
2​
WHENEVER EVERY 1 HOUR
AND HVACBoost (Counter 11) IS GREATER THAN 0
THEN SUBTRACT 1 FROM HVACBoost (Counter 11)
3​
WHENEVER HVACBoost (Task 9) IS ACTIVATED
THEN ADD 1 TO HVACBoost (Counter 11)
THEN ANNOUNCE Miscellaneous 4 (vm242)
4​
AND HVACBoost (Counter 11) IS EQUAL TO 0
THEN ANNOUNCE HVACBoost (Task 9)
5​
WHENEVER HVACBoost (Counter 11) CHANGES TO 0
THEN ANNOUNCE HVACRelease (Task 10)
6​
WHENEVER EVERY 4 SECONDS
THEN DISPLAY "HVACBoost:% CTR11 %" IN Legault House (Area 1) INDEFINITELY, [*] CLEARS
7​
WHENEVER HVACRelease (Task 10) IS ACTIVATED
THEN SET HVACBoost (Counter 11) TO 0
17​
WHENEVER EVERY 6 SECONDS
THEN DISPLAY "Outside Temp % TEMP ZN16 %" IN Legault House (Area 1) FOR 3 SECONDS
35​
WHENEVER EVERY 500 SECONDS
AND Closet Temp (Zn 15) ACTUAL TEMPERATURE IS GREATER THAN 92 DEG. F. (33 DEG. C.)
THEN SEND EMAIL MESSAGE 13 TO [email protected] (Email 13)
36​
THEN ANNOUNCE Heat (vm293)
63​
WHENEVER EVERY 5 MINUTES
AND Outside Temp (Zn 16) ACTUAL TEMPERATURE IS LESS THAN WinterSwitch (Cust Set 2)
THEN SET HVACSeason (Counter 4) TO 1
64​
AND Outside Temp (Zn 16) ACTUAL TEMPERATURE IS WinterSwitch (Cust Set 2)
65​
AND Outside Temp (Zn 16) ACTUAL TEMPERATURE IS LESS THAN DayComfortDo (Cust Set 4)
AND Outside Temp (Zn 16) ACTUAL TEMPERATURE IS GREATER THAN WinterSwitch (Cust Set 2)
THEN SET HVACSeason (Counter 4) TO 2
66​
AND Outside Temp (Zn 16) ACTUAL TEMPERATURE IS DayComfortDo (Cust Set 4)
67​
AND Outside Temp (Zn 16) ACTUAL TEMPERATURE IS GREATER THAN DayComfortDo (Cust Set 4)
THEN SET HVACSeason (Counter 4) TO 3
68​
AND TIME OF DAY IS LATER THAN Waketime (Cust Set 1)
AND TIME OF DAY IS EARLIER THAN Sleep Time (Cust Set 19)
AND WakefulHours (Counter 5) IS LESS THAN 2
THEN SET TimePhase (Counter 6) TO 1
69​
AND WakefulHours (Counter 5) IS GREATER THAN 2
THEN SET TimePhase (Counter 6) TO 2
70​
AND TIME OF DAY IS LATER THAN Sleep Time (Cust Set 19)
THEN SET TimePhase (Counter 6) TO 3
71​
AND TIME OF DAY IS EARLIER THAN Waketime (Cust Set 1)
72​
WHENEVER EVERY 10 SECONDS
AND HVACSeason (Counter 4) IS EQUAL TO 1
AND TimePhase (Counter 6) IS EQUAL TO 1
THEN DISPLAY "Winter Wake Mode" IN Legault House (Area 1) INDEFINITELY, [*] CLEARS
73​
AND TimePhase (Counter 6) IS EQUAL TO 2
THEN DISPLAY "Winter Day% CS4 %" IN Legault House (Area 1) INDEFINITELY, [*] CLEARS
74​
AND TimePhase (Counter 6) IS EQUAL TO 3
THEN DISPLAY "WinterNight% CS6 %" IN Legault House (Area 1) INDEFINITELY, [*] CLEARS
75​
AND HVACSeason (Counter 4) IS EQUAL TO 3
AND TimePhase (Counter 6) IS LESS THAN 3
THEN DISPLAY "Summer Day% CS4 %" IN Legault House (Area 1) INDEFINITELY, [*] CLEARS
76​
THEN DISPLAY "SummerNight% CS6 %" IN Legault House (Area 1) INDEFINITELY, [*] CLEARS
77​
AND HVACSeason (Counter 4) IS EQUAL TO 2
THEN DISPLAY "Cool Day% CS7 %" IN Legault House (Area 1) INDEFINITELY, [*] CLEARS
78​
THEN DISPLAY "Cool Night% CS7 %" IN Legault House (Area 1) INDEFINITELY, [*] CLEARS
79​
WHENEVER THE TIME IS Waketime (Cust Set 1)
THEN SET WakefulHours (Counter 5) TO 0
80​
THEN ADD 1 TO WakefulHours (Counter 5)
81​
AND HVACMode (Counter 7) IS GREATER THAN HVSystemMode (Cust Set 20)
THEN SUBTRACT 1 FROM HVACMode (Counter 7)
82​
AND HVACMode (Counter 7) IS LESS THAN HVSystemMode (Cust Set 20)
THEN ADD 1 TO HVACMode (Counter 7)
83​
AND HVACMode (Counter 7) IS EQUAL TO 2
THEN DISPLAY "HVAC Guest Mode" IN Legault House (Area 1) FOR 2 SECONDS, [*] CLEARS
84​
AND HVACMode (Counter 7) IS EQUAL TO 0
THEN DISPLAY "Bypass HVAC" IN Legault House (Area 1) FOR 2 SECONDS, [*] CLEARS
86​
WHENEVER EVERY 1 MINUTE
AND Legault House (Area 1) ARM STATE = DISARMED
AND HVACMode (Counter 7) IS GREATER THAN 0
THEN SET Downstairs (Tstat 1) TO HEAT
THEN SET Downstairs (Tstat 1) HOLD TO ON
THEN SET Downstairs (Tstat 1) FAN TO AUTO
THEN SET Downstairs (Tstat 1) HEATING DESIRED TEMP TO DayComfortDo (Cust Set 4)
THEN SET Downstairs (Tstat 1) COOLING DESIRED TEMP TO 82 DEG. F. (28 DEG. C.)
87​
THEN SET Downstairs (Tstat 1) HEATING DESIRED TEMP TO WinterDayDn (Cust Set 9)
88​
THEN SET Upstairs (Tstat 2) TO HEAT
THEN SET Upstairs (Tstat 2) HOLD TO ON
THEN SET Upstairs (Tstat 2) FAN TO ON
THEN SET Upstairs (Tstat 2) HEATING DESIRED TEMP TO WinterDayUp (Cust Set 8)
THEN SET Upstairs (Tstat 2) COOLING DESIRED TEMP TO 82 DEG. F. (28 DEG. C.)
89​
THEN SET Upstairs (Tstat 2) TO AUTO
THEN SET Upstairs (Tstat 2) HEATING DESIRED TEMP TO WinterNTUp (Cust Set 10)
90​
THEN SET Downstairs (Tstat 1) HEATING DESIRED TEMP TO WinterNTDn (Cust Set 17)
91​
THEN SET Upstairs (Tstat 2) HEATING DESIRED TEMP TO 60 DEG. F. (16 DEG. C.)
THEN SET Upstairs (Tstat 2) COOLING DESIRED TEMP TO DayComfortUp (Cust Set 3)
92​
THEN SET Downstairs (Tstat 1) TO AUTO
THEN SET Downstairs (Tstat 1) HEATING DESIRED TEMP TO 60 DEG. F. (16 DEG. C.)
THEN SET Downstairs (Tstat 1) COOLING DESIRED TEMP TO CoolComfort (Cust Set 7)
HVACBoost Rule #4: This sets the temp
93​
THEN SET Upstairs (Tstat 2) COOLING DESIRED TEMP TO NightComDown (Cust Set 6)
THEN DISPLAY "HVACBoost:% CTR11 %" IN Legault House (Area 1) FOR 5 SECONDS, [*] CLEARS
94​
AND HVACSeason (Counter 4) IS GREATER THAN 1
THEN SET Upstairs (Tstat 2) COOLING DESIRED TEMP TO NightComUp (Cust Set 5)
95​
THEN SET Downstairs (Tstat 1) COOLING DESIRED TEMP TO NightComDown (Cust Set 6)
96​
97​
THEN SET Downstairs (Tstat 1) COOLING DESIRED TEMP TO DayComfortDo (Cust Set 4)
99​
AND Legault House (Area 1) IS ARMED STAY
100​
AND TimePhase (Counter 6) IS GREATER THAN 1
101​
102​
103​
104​
AND HVACMode (Counter 7) IS EQUAL TO 1
THEN SET Upstairs (Tstat 2) COOLING DESIRED TEMP TO 85 DEG. F. (29 DEG. C.)
105​
AND Legault House (Area 1) IS ARMED AWAY
THEN SET Downstairs (Tstat 1) COOLING DESIRED TEMP TO 80 DEG. F. (27 DEG. C.)
THEN SET Upstairs (Tstat 2) COOLING DESIRED TEMP TO 78 DEG. F. (26 DEG. C.)
106​
THEN TURN ClosetVent (Out 11) ON
107​
THEN TURN ClosetVent (Out 11) OFF
108​
THEN ACTIVATE ReleaseHVAC (Task 27)
Thanks for the tip.
This is going to seem like craziness...
