Hi Folks,
I have a detached garage about 150' from the main house - too far by z-wave design specs - and I'm desperate for ideas on how to integrate the garage into the rest of the house.
I have an HAI 17A00-9 hardwire expander located in the garage itself and wired back to the main OmniPro2 panel, so I'm fine insofar as local security contacts and other sensors for the system. Where I'm stuck is with lighting. Everything is Vizia RF+ z-wave and I'd like to be able to integrate the lighting loads with the HAI programming so that I have a seamless system of control.
I have power in the garage, so I even considered PLC except that it's such an old technology and I have a lot of built-in reasons it likely won't work (generator, lots of UPS systems, and lots of noise such that I doubt the PLC signalling stands a chance!)
I have a post lamp in the driveway island that is about 50' from the house and I've tried using a plug-in module out there to repeat the signal but I just can't seem to make the hop all the way to the garage with z-wave.
Questions:
Questions:
- Is it possible to use a secondary z-wave serial interface routed back to the OP2 board, or is this too long for a serial link (or not even feasible to have two z-wave interfaces)?
- Are there any sort of relay controller options that I could drive off the hardwire expander board to control the local lighting loads indirectly from a HAI-controlled relay instead of z-wave?
- Any super-high-powered z-wave amplifiers/repeaters that can step over the 150' distance needed?
- Any other options I'm not thinking of?
