Our house came with a DSC PC1616 Panel and two DSC PK5501 pads.
The codes were lost so I factory reset the panel.
I have been successful in that the Installers code and master code have been reset to the default values.
I am able to program the PK5501 pad ( gee I love that complexity with all the numbers instead of words ---- not )
I have a green checkmark for ready but also a yellow triangle error.
When I press *2 I get the number 5 - which means that there is a sensor or zone issue.
When I press 5 again it is supposed to tell me which zone is at fault but all I get is a blank screen. I then have to hit ### to get back to the main screen
This is a very simple set up right now with only 4 active zones
zone 1- door set up as a code 01 zone
zone 2- door set up as a code 01 zone
zone 3- door set up as a code 01 zone
zone 4- motion detector set up as a code 05 zone
I went into programing and turned off zones 5, 6, 7 which were labeled as smoke detectors on the sticker inside the panel.
The two pads I have are PK5501's ( the hard to read ones) and they do not have wireless capabilities. I don't think the wireless smoke detectors were ever integrated into the alarm system.
Also, again I do have a green checkmark and I can arm the system, but it wants to bypass a zone when I do that.
Any help would be appreciated.
