maximusbraveheart
Anyone have a guess as to how they may have wired my home phone line: Installed a new M1G & used the prior phone connection that was on the prior alarm. Since we got DSL the system has not been monitored however and the alarm phone jack was not plugged into the old sytem (which was monitored prior to us buying the home).
Anyway the DSL is will not connect when wired to the M1G as directed. I have a hardwired network & phone system & works fine when the existing phone jack in the alarm box is NOT plugged in. Plug it in and it messes up the DSL. Not sure how you use a DSL filter w/ this and why it would be messed up running it through the panel. I only expect the panel phone connection to be noisy due to the DSL signal; NOT the DSL no longer working. Not sure how the phone is wired or how to change it since the phone line in the panel does not seem to run to all the other phone lines in the network box. Maybe it runs back to the main phone feed.
I did a Cocoon search here and did not pull up anything. Thanks!
PS: I got the molex 6 pin serial in the mail already! Will try Monday on the Uplink AnyNet.
