Rupp,
check into dvdshrink.org
very simple to use:
Insert DVD into PC
Launch DVDshrink
Open movie - this will play back movie in it's viewer for about 30 seconds
Click Reauthor
Grab the pieces of the movie you want (like the main movie) slide it to the left pane.
Select your compression needs (none, whatever percent for smaller end file)
Select if you want translations,
Click Backup
Select directory to back up to
Click OK
15 min later you will have a DVD on hard drive which you can burn to a DVD if you want as a physical backup.
